Oven cleaner for rusty frame...
Discussion in 'The Garage' started by speedyvision917, Sep 5, 2004.
  1. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    freind just told me about it today, said when he was redoin his frame on his 85 chevy p/u he bought about 7 cans of oven cleaner from ocean state and sprayed it on the frame then just either wiped it off or scraped it with a wire brush lightly, then bought some rustoleum spray paint and had his hole frame restored for about 40bucks, its a good cheep trick i thought yall would like to no /forums/images/graemlins/waytogo.gif and wonderin if anyones tried it before /forums/images/graemlins/thinking.gif
  2. k5mike
    k5mike Registered Member
    Jul 31, 2004
    29
    Houston,Tx.
    never used it on rust....I know it works good to clean greasy parts..... /forums/images/graemlins/thumb.gif
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Doesn't do anything for rust but it is a good degreaser.
  4. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    yeah, i think a rust reverser would be a good idea prior to rattle canning. Oven cleaner is pretty caustic, and with a wire brush I'd wear gloves,long sleeves and eye protection for sure...
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    it acts as a mild paint stripper.. does wonders on grease too...
    its our standard for taking painted names off the backs of boats... /forums/images/graemlins/whistling.gif
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    thats what I will be using on my frame...
  7. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Works great for engine cleaner--and I can get it for a buck a can,the "Gunk"brand stuff is at least 2 bucks a can,and it sucks compared to the oven cleaner--I think its just a can of aresol diesel fuel. I'm leaning towards leaving everything greasy,and spraying even more oil on my trucks--when my C10 blew the motor it douched the whole firewall and inner fenders--I'm not removing it(ecxept what rubs off on my clothes! /forums/images/graemlins/ignore.gif)in hopes it will keep my frame and sheet metal and brake lines intact another year.I'm going to use an old pump up garden sprayer and sqirt all my vehicles,then look for a dusty dirt road--best undercoating I've seen yet!. /forums/images/graemlins/whistling.gif
  8. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    meriotic acid works too
  9. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i use it for paint all the time. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  10. boggerless
    May 26, 2003
    22,728
    96
    i never tried it on rust but thought about trying. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  11. boggerless
    May 26, 2003
    22,728
    96
    on steel? i use it on aluminum rims here and there but never on steel. does it work? /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  12. speedyvision917
    May 5, 2004
    472
    CT
    not sure, gonna try it tho...couldnt hurt /forums/images/graemlins/doah.gif then again i said that before receiving a 2nd-3rd degree burn on my leg /forums/images/graemlins/doah.gif /forums/images/graemlins/whistling.gif
  13. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    I used muriatic acid on my aluminum wheels once--I put on rubber gloves,and sprayed it on with a spray bottle--by the time I got all 4 rims covered,I noticed the first rim was smoking! /forums/images/graemlins/eek.gif--I immediately hosed them off with water,but it was too late--they turned a deep blackish blue color,that only sandpaper would remove--I ended up sandblasting them,but I think the acid weakened the metal (might have been magnesium,not sure)because next time I changed a flat tire,the bead breaker on my hand powered tire machine broke a big chunk out of the bead area of the rim.I put my steel rims back on after that--I still dont trust the same type of rims on my C10 pickup very much either,they look good,but they arent very strong,I'd hate to hit a curb with them... /forums/images/graemlins/yikes.gif
