Over Filled 700 R4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83ChevK5, Nov 17, 2002.
  1. 83ChevK5
    83ChevK5 Registered Member
    Jun 5, 2002
    18
    Seattle, Wa
    I over filled my 700 r4 what should i do?? /forums/images/graemlins/k5.gif
  2. unsane
    unsane Guest
    I would simply park the rig on an incline and loosen a few of the rear bolt on the tranny pan and Drain it out a little. In a catch can of course.
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    or at idle loosen a cooler line, and let slowly drain untill you get it at the right level
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    For every ~5/8" on the dipstick you're about a quart over full in my experience. Get a piece of hose and unhook the line feeding the fluid cooler. Put the hose on the end of that and the other end into something to contain the fluid. Start the truck. Run over and watch to see how much fluid comes out. Be prepared to run back around and shut off the truck.
    It comes out pretty quick, especially if your truck is cold and the fast idle is on.
    The previous owner of my truck noticed that it was leaking ATF. Well, they must've thought it was the transmission even though you could see where it was dripping off the transfer case. The transmission was about two quarts over full and the transfer case was about two and a half quarts low. Rocket scientists, I say.
  5. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    Pick up a small hand pump at your local auto parts store. They work great for stuff like that.
  6. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    Here is the easiest way to do it. Go down to your local quick lube and ask them to use their evac-tube to suck the tranny fluid to the right level. it is just a long thin piece of flexible tubing you feed down the dipstick. I have done this many times for people at my lube shop. I am sure every lube shop has one and they will know exactly what you need.
