Over heat on hills only
Discussion in '1982-Present GM Diesel' started by ZuluNashun, Apr 22, 2002.
  1. ZuluNashun
    ZuluNashun Registered Member
    Sep 21, 2001
    26
    Salt Lake City, Utah
    The other day i was driving up the mountain to do some powder surfing in the April snow, and my 6.2 temp shot up to 240 in maybe 5 min of doing 30 mph up a 6% grade. I would pull over and let it cool but as soon as it got moving up the hill it spiked hot again. This has never happened on the freeways with the throttle pegged. Could it just be the thermostat? Normal running temp is 200. Thanks
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Thermostat, water pump, or temp. guage not reading right.
    I'd start with changing the thermostat. If you can, use RobertShaw 180 degree. They're a lot better quality.
    Casey
  3. ZuluNashun
    Sep 21, 2001
    26
    Do I get that at autozone?
  4. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    If the engine overheats only at large load and slow speed, then mostly is it a problem of the fan clutch.
  5. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
  6. ZuluNashun
    Sep 21, 2001
    26
    So, does the fan clutch go out and the fan only runs at engine speed? How do I tell if my fan clutch is bad? Or should I just replace that no matter what?
  7. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    The clutch is filled with liquid (silicon oil) and the fan is only moveable strongly by hand. If the clutch turns too easily, the fan is too weakly propelled and cannot cool sufficient. A e-fan is ideal in such situations.
  8. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Maybe theres a better way to check the fan clutch than this, but this how I would do it. The next time your truck over heats, shut if off for just a moment. Then, get out and try to spin the fan by hand. It should be difficult if not impossible to spin the fan if the clutch is engaged. Be sure to check it right after you pull off, otherwise it might start to disengage without hot air flowing over it.
  9. ZuluNashun
    Sep 21, 2001
    26
    I think I'll try that. It sure gets the blood flowing when you look down and see your temp at past the red on the gauge. I got all light headed and woozy.
  10. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Yes, I second the Robert Shaw T-stat... I used part #370-180 from Autozone. About $7.
  11. ZuluNashun
    Sep 21, 2001
    26
    I took it out, got it hot and tested the fan. It doesn't turn freely. There isn't a great deal of force needed to turn it. So I guess it can't be that. I'm going to buy a new therm and try that.
  12. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Might want to peer into your radiator. (Helps to see if you have a low coolant level). Mine was heating up on the highway hills (at Summer temps). I looked into the radiator and it was full of CRUD! 'Brought it to a radiator shop to have it "rodded out".
  13. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    I believe that the stock radiator is large enough and can regulate smaller blockages. If several lines are closely, the engine will overheat in all operating conditions. I’ve had temperature problems only if the air condition is switched on, if transmission and engine oil are hot and few air flow are present. Since I fixed two e-fans in front of my radiator, heat isn’t a topic no more…
