Over heating problem
Discussion in '1982-Present GM Diesel' started by cegusman, Apr 7, 2004.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Been having an overheating problem lately. The 6.2 has always run at 190 like it should. 4 weeks ago I went muddin. Hit a very deep hole "up to door handles in water". Coated the radiator with the mud, mud dried and the motor over-heated, caught it at 230, shut it down. Pulled radiator cleaned all the mud out. It now stay at 190 at idle and when driving on the road, like normal. But out on the trail at slowwer speeds it starts to over heat. Hit a mud hole last weekend, was reved close to full trottle for about 30 second and the temp shot for 190 to 260 real quik. Going to pull the t-stat and run it and see if it is the problem. If not I will swap the fan clutch and hope. I have no water in the oil and no water coming out the exhaust, so I don't think it is a head gasket or a cracked head. What else could it be? After I figure it out I am pulling the diesel and swaping in a 350 /forums/images/graemlins/yikes.gif need better wheel speed.
  2. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    After I figure it out I am pulling the diesel and swaping in a 350 need better wheel speed.
    /forums/images/graemlins/shame.gif
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Wanna trade for a Olds 455? /forums/images/graemlins/deal.gif
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Would do it but shiping/fright will suck.
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    As long as the tires are cleaning themselves you have enough wheel speed. Boggers self clean at a fairly low speed...
    I'd say the manual tranny is hurting you more in the mud than your redline is, and don't forget the 6.2 is governed whereas a 350 can be over-revved and damaged.
    As for your overheating...I'd guess the T-stat got fried.
    rene
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    rene
    Will check the t-stat today, but it think it is fine. When the motor warms up, the temp goes up to about 190-195 then drops to 175. So I know the t-stat is opening. But who knows, I will swap it out anyway. Will keep this post updated.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You think you are having problems in mud with the 6.2, wait till you try a gas engine, mud will be your enemy.
    If you like mud stick with the diesel.
    Now for your overheating, do you have a clutch fan, check to make sure it's clean from mud and that it still operates right.
    When it's hot it should be almost solid with the shaft.
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Been talking to a few friends and we have think it has to be the fan clutch too. Called the parts store to order one, they say they have 2 a 4bolt one $60 and and an 8 bolt one $170 /forums/images/graemlins/yikes.gif, don't have the truck in front of me not sure which one I have. Was one more common than the other?
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Maybe it was AC truck versus non AC truck? You'd think an AC truck would have to pull a little more air...
    Rene
  10. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    It was the fan clutch.
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I'm gonna assume you figured out which one you needed...
    Rene
  12. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yep, it was the 4 bolt.
