over heating
Discussion in 'The Garage' started by purple76pearl, Jan 13, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    i have a 3 core raditor, and a b&m tranny cooler rated at 28,000 i think, but burnt up one tranny, and catn keep the motor under 210, any suggestions /forums/images/graemlins/k5.gif
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ok, is your tranny cooler in front of the radiator or behind it? its supposed to be infront i believe, and for the engine you might try an oil cooler as well, that might have some effect a friend of ours with a 55 chevy with a 396, had that same problem, put on a oil cooler and its all good.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Put a raditor out of a big block truck in there. Also maybe a 165 degree thermostat.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    How old is the radiator? If it's an oldie, then it can look OK but still have lots of clogged cooling tubes. /forums/images/graemlins/frown.gif
  5. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    How about the fan clutch. after your engine has been a full temp for a while shut it off grab the fan and try to turn it if it turns you have a bad fan clutch. Are you running a fan shroud it will help to.
