Over-stressing axles
Discussion in 'The Garage' started by Mad-Dog, Apr 7, 2005.
  1. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    i notice a lot of people installing tires and and wheels with little or no regard for axle strength, dana 44's are rated for a maximum tire size of 33".
    installing anything bigger is a invitation to disaster
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  3. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    nah
    depends on if you wheel your rig hard. i would say 36s max, but you will break a few axleshafts if you do anything but mud
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a 10 bolt is no difference in strength than a d44, right? i have wheeled hard with my 10 bolt and 35s with no carnage. a buddy has broken 1 ujoint on his truck with 38.5 tsls and a 10 bolt in 2 years of hard wheeling.
    its how you wheel AND maintain your stuff.
  5. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    i ran 38x11 boggers on a dana 44 with a doubler and a mild small block chev. It held.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Whats the point? If you wheel a truck hard with 33's you will still stress alot of parts beside and including the axles.
    I broke a factory gov-lock in my 10 bolt rear with 32's. According to you it is rated for 33's but still broke.
    I have a locked 10 bolt front that has 35" tires. I rock crawl it and have only stretched the ears on 1 stub axleshaft.
    Harley
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I run 33's on my IFS daily driver and I used to torture that thing and everything has held up fine...I'm not sure I understand the point of this thread... :dunno:
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I'm having a hard enough time keeping chromoly shafts together in my 60, maybe I should swap in a 44? Anywho...
  9. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    39.5x18 boggers and no problems on my 44, sees mud every weekend, held up fine for almost 2 years
  10. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Don't get me wrong here folks.....i never said it wont work.
    i think it is a invitation to breakdown, hardened axleshafts, trusses and floaters all contribute to strengthen a axlehousing.
    personally, i would follow the manufacturers guidelines and Dana rates their 44's for a max tire size of 33".
    So my point is if you fail to follow the manufacturers guidelines then you're inviting disaster.
    These are just my opinions and should be taken as that......... :(
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Wow :eek1:
    I don't even know where to start with this. I am speechless.
    Well lets talk about invitation to disaster, Putting anything in your pocket can puncture your liver if you fall just right, placing anything inside the cab of your rig can cause it to decapitate you in a sudden stop.
    Show where dana says that 33's are max. I am raising the BS flag right now.
    As for manufactures guidlines, they are recomendations for sue happy morons, not laws governing modifacations. I am trying to restrain myself, but what is the ideal set up for 33's?
    Also why did the factory offer the D44 under both 1/2 ton and 3/4 ton, auto and manual, diesel and gas, in all of the big three, if they were inherently weak?
    Agian, where is my BS flag, I can't find it.
  12. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    I still don't get the point of this thread. The great majority of us here are well aware of the 1/2 ton limitations...you're preaching to the choir.
    On the other hand, as Harley pointed out, many of us have broken those diff's with even smaller tires...and quite a few of us regularly abuse those same axles with 35's, 36's and sometimes larger.
    Trying to define the real world upper limit of a D44 or 10 bolts strength is not exactly cut and dry. Age, maintenance, quality of replacement parts used, type of tires, type of terrain, and most importantly driving style, all factor into it. If you're comfortable looking at all those variables and saying "33's are the definitive upper limit" that's great. I for one feel the true answer is "It depends".
    Rene
  13. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I know what you're trying to say.. But most guys on here know the jist of what is ok to run etc. If someone chooses to run tires bigger on a 1/2 ton, or 3/4 ton set up they know what type of driving is required to keep it together. Sometimes the law of averages comes into play, and something breaks... and often it does not. It's a give and take. Not everyone can afford to upgrade to a D60/14 and even if they could, it's still not fool proof. Smart driving can make almost any system work just fine.. foolish driving can ruin even the best "bullet-proof" set up. And again, even a well built rig, with cautious driving will sometimes choose to break something ... just to show you it can. :crazy: The main thing is, have fun with what you have. Like the article that RJ wrote.. back in the 80's we just wheeled what we had.. there was never any talk of upgrading parts.. no one cared, and not much was even offered. It was fun, and we had fun doing it.. I knew guys running 39's on 10 bolts.. who never broke anything. We were not locked.. and didn't flex for crap.. but we learned to get into places with good driving skills, to offset the lack of equipment... and we always came back dirty, with big grins and plenty of storys to tell.
    heres to the old days.. :saweet:
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    This is some funny stuff, I got a good giggle out of it.
    I'm not sure if you're serious or not though.
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'm pretty sure the max. reccomended size for a D60 is like 37 or 38 inches...so are we all supposed to run out and buy 2.5 ton gear?
  16. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Oh man, I just bought 40's, you are saying I have to get rockwells?
  17. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    was: over-stressing axles
    I don't care what you do anymore...
    Sorry for posting a thread here... it wont happen again.
    C-ya
    P.S. Ryan B. can find me on alt.autos.4x4.chevy-truck.
  18. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Wow, after viewing your website........
    GM never put a 575hp engine in front of a TH350, so you probably shouldn't do that.....
    GM didn't make it a habit of equipping their vehicles with nitrous oxide, so you probably shouldn't do that.....
    GM didn't twin stick their NP205's, so you probably shouldn't do that......
    :surepal: :dunno: :deal:
    :haha: :haha: :haha: :haha: :haha: :waytogo: :waytogo: :waytogo:
  19. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    :dunno:
    C'mon dude.. don't get all serious -n- chit. I think your post just suffered from a lack of point... and fore thought. Chalk it up and move on... lifes to short.. and so is Tim.
    No harm done.
  20. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl:
