overdrive opptions for cummins power
Discussion in 'The Garage' started by original balzer, Jul 23, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    so i hauled basicaly a house full of furniture & everything else involed in a move a little over 300 miles this week now i want a cummins i know of 2 pre 94 cummins trucks i should be able to get fairly cheap as they are both wreaked they are both autos and 2wd though i dont know what tranys with over drive will hold up to a 6bt after i do some power mods i would like a manual 5 or 6 speed but i have no idea what units are strong enough for alot of tourqe is a NV4500 enough are there autos tough enough without going to all dodge drive train?
    balzer
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    go with a nv4500, they are tough, have a good low gear and overdrive. but they get a little expensive
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    NV4500 and NV5600 come with the cummins. i have an NV5600 in my new truck. they are putting some in house built G56 in now, that would also bolt right up once adual mass flywheel was installed. that could take some work as i dont know if the crank bolt patern has changed at all. NV4500 would work, but OD isnt as much as it could be. the NV5600 has a lower first gear to make up for taller gears if you like.
    Grant
