Overdrive Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Dec 2, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Why should I not drive in overdrive all the time? What happens when I do drive in overdrive? Thanks.
    [​IMG]FUN WITH 31's![​IMG]
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the way i understand it if you are in overdrive in town there is to much stop and go and slower trafic and it is constantly shifting 3rd to 4th, 4th to 3rd and so on and that is hard on it. i have always been told to have it in drive in town and overdrive on the freeway. anyway hope this helps
    s.smith 77blazer lookin 4 mud
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    When it constanly hunts fro gears like that, it builds up heat and thats what kills trannys. Also if you have it in OD, at least for me, it shifts into 4th at about 50 mph, and you don't get any acceleration. You really only need OD for 65+. I have 3.42s and 33s
    90K5
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Hey 90, How are you with the power you have with the 3.42's and 33's (rpms and all that). Thats what Im in the process of, soon as I get me 4" lift in. Was thinking Im going to need the go down on the gears.
    Don't you buy no ugly truck!
    http://"mccordhouse.freeservers.com"
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    When your tranny "gear hunts", the internal components in your transmission work harder and get hotter, like 90K5 said above. In addition, your tranny cools itself by circulating it's own fluid out to the cooler and back.
    If you are in overdrive at city speeds, every time you let off the pedal, the tranny will drop to OD, but even a small ammount of load will kick her back down into D. This causes heat buildup. Now add to the equation the fact that in OD your tranny fluid circulates about 30% slower. Not only do you have a higher than normal operating temperature, you also have a less efficient cooling system. Basically, you're slowly frying your transmission.
