Overdrive ratio- 700r4?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Foy, Sep 10, 2003.
  1. Foy
    Foy Registered Member
    Oct 28, 2002
    34
    Raleigh, NC
    Hi guys-
    I'm thinking about putting some taller tires on my stock 1990 K1500 Suburban. It's a daily driver, not wheeled except for on the beach here in NC. The truck is running better than it has in a long time, and even with 182,000 miles on the 350, the cruising power/torque are great. I don't want to mess up the highway cruising by putting too tall of tires on it, so I want to be able to calculate the RPMs that she'd turn at 65 mph, after adjusting for the taller tires. What I'm missing is the locked-up final drive ratio of the 700r4's overdrive. Dad says he thinks it's a 20% gear, so 0.80/1.00. Is that correct?
    By the way, I'm thinking of something like 32-33" tires, non-aggressive tread, something like 11 to 12 x 32 to 33, and they'll need to fit on my OEM Silverado alloy wheels.
    Thanks for any help on the o/d ratio. I've got the RPM formula covered.
    Cooper
  2. dyeager535
    26,975
    Actually I believe it's .70, but an online search should also yield the gear ratios of the 700.
    What gears are you running? Personally I wouldn't consider 33's on a truck with 3.42's and overdrive. You'd cruise 60 in 3rd gear.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Correct. .70 is the overdrive for a 700-R4. Also, with 3.42's I would not go bigger than a 32x11.50R15 Plus your wheels are only 7" wide. The 11.5" should be pretty much max on that wheel.
    John
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Stock tire on that truck is a 235/75R15. That's right around 29". For you to keep it in good cruising condition, don't go any bigger than 31". A 31x10.5 would really add the look you want without hurting crusing characteristics that much. I drive the exact same truck as you stated (90 K1500 suburban, 700R4, 3.42's - except for I'm running a 4" lift), and the 33's I have on there really mess with freeway driving.
  5. dyeager535
    26,975
    I thought it was finalized that all 1/2 ton 4wd trucks had 15x8's, while the 15x7's were only on the 2wd variants?
  6. heavy4x4
    Aug 28, 2002
    3,270
    The '90 K1500 Burb has 15x8 wheels. /forums/images/graemlins/thumb.gif
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Same as Heavy4x4, I too have a '90 'Burb with the 3.42's....I took the 31's off beforereally using them, and went with some 32's I had laying around....I didn't even use the OD even on the highway, it just wasn't a happy combination....
    Now with 4 inches of lift and 35's I am swapping to 4.56's to get back some driveability....I say 31's.....
  8. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    I must go with a 10" rim then, I don't like how the 12.5 wide tire sits on the 8" rim......
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I've ran 33's with the 3.42 gearing and 3.73 gearing. In my K5. I wouldn't do it in a Sub though. I was always a dog on the hills with both gearsets and how much more does a Sub weigh more than a K5? Definately think about moving another gearset up.
  10. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I have a set of the stock aluminum wheels from that era. I am 99% sure they are 7" wide, but I'll double check tomorrow. If I'm wrong, please disregard my commments above. /forums/images/graemlins/ignore.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
    John
  11. dyeager535
    26,975
    wheel width thread
    Only one I could find. But from other threads, looks like AL wheels were 15x7, steel 4wd were 15x8. 2wd must have been 15x7, and there is even reference to 15x6, but it didn't appear that was confirmed.
  12. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I have 3.42's and 33's on my Jimmy. Its a little doggy on hills. I can cruise 75-80 on the interstate and only turn 2200 RPM in OD. Is that bad? It doesnt ever come out of OD by itself in the mountains but it is always coming out of lockup so I can keep the speed up on hills. Sometimes I pull it out of OD so I can get up the hill quicker. So is there anything to be concerned about with my gear/tire combo?
  13. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Not if you are happy with it, just put in and watch the trans temp gauge....
    My driving is mostly in town and two lane, I want to get back some performance....
  14. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I did mean the AL were 7". I checked and there 7". The steelies are 8" for sure /forums/images/graemlins/thumb.gif
    John
