Overdrive surging
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheGeneral, Mar 11, 2001.
  1. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Problem, 89 K5, TBI 350, 700R. Been running great. Just recently, once truck is in OD and cruising, any throttle demand not sufficient to cause downshift, results in what feels like surging. All else, engine, trans, runs fine. Debating on Trans or looking at TPS, IAC, EGR. FIrst real ECM controlled for me, so it seems from others, what seems like the problem (trans/converter) may be a sensor. I will start reading what codes it is throwing tomorrow, but wondered if anyone else has had problems like this one.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Is the check engine light coming on? Well if you can get a scan tool it makes reading all the sensors much easier... can even do it while you drive [​IMG]
    1987 Chevy K5 Blazer- 350 TBI
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    TV cable...it may not be set properly. Grab a Chiltons or Haynes and it should tell you how to set it.
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
  4. CK5
    May 19, 1999
    21,625
    702
    CO
    Mine did this over a year ago, dumped a quart of Dura Lube in and no more surging.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  5. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I know that this will sound crazy but it did drive me nuts for a month. Check the plug wires for arcing when hot and under load. I chased down tranny and EFI guesses and finally did a tune up one part at a time. I found that the number six wire was defective. It only failed when accelerating with the vehicle hot and in OD. Hope this helps.
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Sounds like an engine problem and not a transmission problem to me.
    <font color=green>Stupid tourist at Mammoth Cave, Kentucky: "How many miles of unexplored passages are there?"</font color=green>
  7. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    Mine has done this twice in the last year and both times it was the timing. Check it out.
    89'Sub 350 TBI 190,000 miles.
    One From None
  8. dyeager535
    26,980
    I had a nasty part throttle (cruising) surge with my Q-jet. It turned out to be one bad plug. Amazingly enough, the difference at idle was imperceptible until I put in a good plug and then tested it connected and disconnected.
    Dorian
  9. TheGeneral
    Feb 22, 2001
    556
    NC, USA
    Hey guys, thanks for all the info. I went to Autozone, bought rotor, caps, plugs, EGR, TPS, IAC, O2, coolant sensor and replaced all, and worked on the TV cable. She is running now alright. About 150 total, and 6 hours. I checked the codes, and I was throwin four different ones, so good news is now that all works, but I think the coolant sensor is not working as no temp indicator, so have to return and get another one. I decided to do all of it considering I have know idea what previous owner did to it since 89, and my wife had a 89 Beretta that I screwed around with for about 3 weeks replacing sensors one at a time (was the TPS). I liked the DuraLube fix though Steve, will now always have to try that every time something is wrong. Hopefully I will get my web pape up and running soon, to show off the BigUglyK5.
    The General
