overdrive tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer_Schwabie, May 15, 2003.
  1. Blazer_Schwabie
    Blazer_Schwabie Registered Member
    Feb 21, 2003
    15
    Washington state
    i have a 1980 blazer with the 3 speed automatic and i was wondering if i could switch it out to one of the newer trannys with over drive? If so, which years? thank you
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yes you can switch to a 700R4 which has OD. I think any of the years after 84 are good. You will need an adaptor between the tranny and T-case. I am not sure if you need driveshaft mods or not. Someone will correct me if I messed anything up.
    -Brian
  3. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    May have to move the transmission crossmember
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Try to find a tranny out of an 89 or newer truck those are the best years of the 700r4/4L60. They had all the factory upgrades and are the strongest most dpendable units.
    Heres some info on how to Id those years:700r4/4L60 trans ID
  5. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Okay my .2 cents, If you are planning on running bigger tires be ready to have to do gears. The 700 doesn't like running stock gears and big tires in OD. If you change it ,yes you will need to move the crossmember back about 2 inches, due to the 700 being longer. Your shafts I am not sure about. I have a 700 and 4" of lift and no problems on mine.
  6. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    Very good info /forums/images/graemlins/thumb.gif
    Shane-
