Overdrive transmission
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dammit32, Aug 18, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    When i aproach hills at 40-50mph the tranny trys to go into the passing gear and the whole truck vibrates...if i step on the gas or let off it goes away...is there a selenoid that makes this do this or some vacuum thing...it just feels like it doesnt completely engage...or is my tranny on its way out
    any feedback would be helpful /forums/images/icons/confused.gif
  2. Rayven90
    Rayven90 Registered Member
    73
    FT Lupton, CO.
    Boy it seems like there are a lot of tranny problems lately. My 90 had the vibration(chatter) and I found out that it was that the clutches had worn the friction material off. Of course this led to a rebuild. I felt the exact same thing with my throttle. Under accel or decel I felt nothing. Only when there was no real load.
    Ray
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    You're probably in overdrive and the transmission is complaining. The torque converter is probably unlocking and locking constantly and/or dropping to third gear and coming back up. This is what kills the 700R4. Certain death to a 700R4 is some goofball doing that with a 2000lb trailer behind them.
    Simple solution: don't use overdrive if you're going to be around hills. In fact, don't even use overdrive unless you plan on going 55mph or faster.
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I had similar probs with my wifes 87. just told her to drive in 3rd unless over 55 on highway.
