overdrive
Discussion in 'The Garage' started by dukhuntr5, Apr 6, 2007.
  1. dukhuntr5
    dukhuntr5 Registered Member
    Aug 22, 2006
    7
    southaven,mississippi
    Got a question for you transmission gurus. Had a 700R rebiult recently and it has no overdrive. Is this major parts failure or is there an easy fix for this?
  2. Low76K5
    Low76K5 Registered Member
    Jun 28, 2005
    33
    Rapid City, SD
    700s are a pain. I own one. Throttle pressure is the key to everything. That is the slider adjustment at the carb.
    Take it to your trusted tranny shop and they should be able to adjust-either be feel or with pressure gauges so everything works fine.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Did you set up the shifter on the column again when you put it back in? It's easy to get them a bit out of line and only have it in D even though it may indicated OD on the dash. Check fluid level again and set the TV cable as per instructions at www.tvmadeez.com article 101 at top of page.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Are you sure is has no OD? Maby the TC is just not locking up. Check to see if the TC lockup wires are plugged in.
