Overdrive?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Glenn312, May 24, 2000.
  1. Glenn312
    Glenn312 Registered Member
    May 21, 2000
    9
    Maine
    Somebody told me that automatic transmission on 1990 Blazers/Jimmys go bad quickly. Does anyone know if this is true (hopefully not). Until then I will try not to use it.
    1990 GMC JIMMY SLE w/350
  2. Can Can
    15,555
    151
    Cochrane, Alberta, Canada
    You shouldn't find any problems with your tranny as long as you drive in D at lower speeds. I normally switch to OD after I hit around 80kph. Another thing to avoid is towing in overdrive. If you just bought your truck, it might be worth it to do a tranny service and check your fluid closely for metal and discoloration. Unforunately, Chev overdrive trannies just aren't as tough overall as some other makers.
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If you search this site for "700r4" or "700R4" you will come up with LOTS of posts about your tranny (TH700R4 is the official name for it), including ways to get maximum durability and lifespan from it. Enjoy!
    [​IMG] Semper Maintenance!
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    If your k5's lifted and you don't have the proper gear ratio, don't use OD.
  5. walrus101
    walrus101 Registered Member
    Apr 9, 2000
    91
    texas
    the 700r is basically a good tranny. they haven't worked all of the bugs out of the earlier year modes (like we have, mine is 88). they are known for over-heating. this is why the others are saying drive in..well..drive not o/d. less shifting less heat. if you don't have one,i would suggest getting a tranny cooler. i don't have one yet, but will soon. they are cheap and relativly easy to install. there are a lot of mods for them, too.
    walrus101
    goo goo gaju
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Get a tranny cooler and an B&M deep trans pan. By the late 80's most of the bug were worked out of the 700r4. Also check adjustment of the T.V. cable and change fluid at 30,000 mi. I usally change my fluid around every 20-25,000.
