Overdrive?
Discussion in 'The Garage' started by 84gmcjimmy, Mar 1, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey, for you automatic guys, I was wondering what overdrive is? As you can tell with some of my Q's, im in the learning mode!! /forums/images/graemlins/thumb.gif
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Overdrive is a an extra gear in an auto tranny, it has a higher ratio than a regular non-o/d tranny, enabling lower RPM on the highway, which means deeper gears can be run in your axles and o/d's usually have a lower first gear ratio than other autos /forums/images/graemlins/thumb.gif
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It's an extra gear made to save gas when you are cruising at higher speeds. Some guys choose to put lower gears in the axles than they would with a non OD auto tranny to gain more offroad power but defeats the OD purpose as far as saving gas. It just depends on what someone want's to do with the truck.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    It's a gear that makes the output shaft turn more revolutions than what's coming in.
    How does this apply practically? Your engine will run lower RPM's at cruising/freeway speed, than an equally equipped truck with a TH350, TH400, or SM465 (all the top gears for those trannys is actually 3rd gear in a 700R4). Be careful though, if you run too low of RPM, your gas mileage may suffer because you're no longer in the engine's power-band (between 2200-2500rpm).
    With an overdrive tranny, you can run lower gears (higher numerically) in the axles to get better take-off/acceleration/crawl-ratio and not have your engine screaming while on the freeway. /forums/images/graemlins/waytogo.gif
  5. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    most common auto trannys among k5s are 700 r4,if built right,ive been told they can be pretty tough.Isnt that right ,Bobby? /forums/images/graemlins/grin.gifJake
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    That's the definition I had in mind /forums/images/graemlins/thumb.gif
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]definantly! /forums/images/graemlins/waytogo.gif
    To a point though...and no Jake your not past that point. /forums/images/graemlins/smile.gif
  8. hi pinion
    Sep 25, 2003
    5,354
    I know a good cooling system is a must for those 700s....in on my 3rd /forums/images/graemlins/deal.gifoops 4rth 700.Got a "VOODOO" tranny lol /forums/images/graemlins/hack.gif /forums/images/graemlins/grin.gif
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Thanks for the replies guys! /forums/images/graemlins/bow.gif
