Overfilled tranny
Discussion in 'The Garage' started by jagerman, Mar 18, 2007.
  1. jagerman
    jagerman Registered Member
    Feb 12, 2007
    6
    here
    What can happen if you over fill your transmission?
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    when it gets warmed up it has potential to spit it out the dipstick tube, onto your hot exhaust, causing it to catch fire and take your rig with it, leaving a pile of burned up useless crap. that would be worst case though.
  3. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    yup, and then the world stops spinning and life as we know it is over...ect ect...
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yes it can spit out of your dipstick and cause a fire. Overfilling it will put more pressure on seals and whatnot which could make them more prone to leaking. I overfilled the tranny fluid in my dd because its german and when I saw the dipstick looked a quart low, i added a quart. Well...since its a mercedes, they measure it in pints so it is now about half a quart full. I never bothered to drain it out though because the car has 300,000 miles on it and the extra fluid made the shifts more quick and I kind of like it.
    -Harrison
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    uuuh, my Suburban along with all my other Chevys are measured in pints as well, not just a "Mercedes" thing
  6. Mississippi4x4
    Mississippi4x4 Newbie
    Mar 1, 2007
    south mississippi
    sure you don't mean quarts?
  7. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    tranny "add" lines are usually a pint... motor oil, qrts....
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
  9. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    Your avatar freaks me out.... :wink1:
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It depends on how much you overfilled it. Overfilling the tranny some is a trick some of the rockcrawlers use to help the tranny keep prime at very offcamber moments. I typically keep my 700R4 right at the top line or just above it for the angles issue. I have never had it loose prime on me yet. I don't have any leaks that I am aware of. The Tcase leaks like a bastard but the tranny doesn't.
    Harley
  11. 87BrnRsd
    Apr 21, 2003
    2,457
    Learn something new everyday. It does seem stupid that when you look at the specs on transmissions they always say they hold like 12 quarts....but the dipstick measures in pints. weird.
    -Harrison
  12. NorCalKid
    NorCalKid 1/2 ton status Premium Member
    May 6, 2005
    1,604
    7
    Davis California
    If you fill it too much the fluid can get air in it, then the shifts start getting funny. But I think you really have to overfill it for this to happen.
