overhead shelf
Discussion in '1936-Present Suburban' started by tx_sub, Aug 2, 2004.
  1. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    has anyone installed that shelf that hangs above the windshield? i have seen some in pics of newer subs with the overhead console. does it fit over ours? and anyone who has it do they like it? TIA
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    would be very interested as well. Burbs main flaw as of right now is storage. Sure plenty of room in the back but no little pockets to place my change, cellphone, CDs. They all end of on the bench sliding back and forth.
  3. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I bought one form Summit witht he center overhead console for my 88 about 4 years ago. Comes in real handy. The only down side is things tend to get bounced off when you hit many bumps.
  4. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    places like cabelas have ones and they say they have them for all veacals, look good i have thpought about them befor. /forums/images/graemlins/woot.gif
  5. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Yeah I have one in my Burb.
    I like it, took a little getting used to as it hangs down a bit.
    I also had to modify the mounting brackets so that I could push it closer to the windsheild and tuck it up a little higher.
    Mine is the old SteelHorse design that is discontinued though.
    As you can see from the image I have a center piece as well that I mounted my power mirror controls in and will mount more light switches and aux gauges too. I can try to get a better shot of it mounted if you want it.
  6. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    allow myself to re-explain...myself
    i meant the factory overhead console in the sub. how well do the shelves fit over the console. is it snug or is there just enough room for crap to slide in there and be a pain to get to. (easy fix tho).
    please respond
    and one more thing, what happens to the factory visors? are they replaced. are the replacements nice?
    appreciate it y'all
  7. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    THE visors re-screw into the shelf
  8. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    OK, got you now./forums/images/graemlins/waytogo.gif
    I have a factory overhead center console too, just not installed. The older Burbs could get an overhead console, not as nice as the newer ones but it was the same as the old Astro overhead console.
    With the brackets my shelf kit came with there was enough room for stuff to fit in there no prob and I could still get my hand between the two to pull stuff out, I just couldn't use the center piece that came with my shelf.
    The factory visors do screw back into the shelf but I had to bend the crap out of the mounting arms in order to get them to sit flush again after being reinstalled. They sit up there nice and tight now, but if I have to drop them I loose way to much windsheild to safely drive.
    As far as shelves for newer Burbs, I have seen some designed to work around the console. I think they may be two pieces that mount on either side of the center console and give you two seperate shelves then.
