overheat light
Discussion in '1982-Present GM Diesel' started by domator, Aug 26, 2002.
  1. domator
    domator Registered Member
    Feb 20, 2001
    12
    Poland, Europe
    At what water temperature does the engine overheat light go on in a 6.2 diesel engine? How is the temperature sensor calibrated?
    Piotr
    chevy m1009
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    As far as I know, my 83 isn't equipped with such a light. Maybe it is but I've never had a chance to see it in action(Thank God /forums/images/icons/smirk.gif ).
    The only warning I have related to the cooling system(other than my temp gauge) is a "Low Coolant" light below the speedometer. I'm not sure where the sensor is or what it reads, but it has to be either actual coolant level or maybe system pressure. It used to come on sporadically and everytime I checked the system was full to the top.
    Anyhow, enough sidetracking. Sorry I couldn't be more help. If you find out anything else keep us posted. I'd be curious to find out more about it.
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I have an 83 and am yet to see an overheat light. There is a low coolant light. The sensor is located inside the radiator. There is a wire on the outside passenger side of the radiator.
  4. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    I am sure Piotr have an Ex-Army model. They have warning lamps instead gauges. Rumors maintain, soldiers cannot read. Sorry Diesel Dan.
