overheating after replacing t-stat
Discussion in 'The Garage' started by bettabruce, Mar 15, 2005.
  1. bettabruce
    bettabruce Registered Member
    Feb 7, 2005
    19
    Jackson, MS
    My truck is still pegging out around 220 or 240 and dropping
    back down around 200 after I replaced the thermostat. What
    are some other possibilities?
    Thanks in advance.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I will make a list of things that need to be checked or replaced that could cause engine overheating.
    Radiator cap
    Radiator
    hoses
    belts
    water pump
    thermostat
    clutch fan/electric fan
    thermal electric fan switch
    Any number of these items can cause an engine to overheat. Did you install the thermostat correctly? The side with the spring goes to the engine side.
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I didn't have time to change a blown headgasket and clean out the cooling system one time so I took the merc wagon to a local shop to do the work. Left San Jose at night and drove to Bakersfield after the work was done. The next day when the air temp got hotter and the car overheated. Got a new thermostat for it. When I went to change the Tstat I found the shop had put it in backwards. That sure pissed me off.
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I know this may sound stupid but do you have the fan shroud in place? Or did you do a body lift and modify the shroud?
  5. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    After running the engine and expel the air pockets, did you top off the radiator?
  6. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,268
    159
    Wisconsin
    Here's what I'd check, some of it is already mentioned.
    1 - top off coolant level
    2 - thermostat in backwards
    3 - faulty new thermostat
    always get the premium thermostats, the cheapo ones almost always go bad within a year or even sooner. Spend the extra few bucks and get the premium thermostats, like the stant premium version, or the robert shaw units are real good ones.
