Overheating at a stable 220F?
Discussion in 'The Garage' started by bettabruce, Mar 16, 2007.
  1. bettabruce
    bettabruce Registered Member
    Feb 7, 2005
    19
    Jackson, MS
    My 1975 K5 is running at 220 all the time.
    I've replaced the thermostat and had radiatior recored.
    Is 220 acceptible temp in 75 degree ambient weather?
    I have a pretty much stock 350.
    Thanks in advance for input.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    nope , a hair over thermostat temp shouldn't be a problem in agood cooling system .
    Look the system over again . Maybe a fan clutch or something is working right , provided you have already made sure you have no leaks .
    BTW , when was the last time it was flushed , and does it have coolant or straight water ?
  3. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    Have you determined that the temp guage is accurate? The factory guages are notorious for being hard to trust (especially after 32 years.)
    Rene
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I always overlook the easy stuff , as I fixed those things years ago when I bought my Blazer .
    Yup Renes correct , verify the gauge first and foremost .
  5. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Do you have a fan shroud, or body lift? Guess it could be alot of things but... you get one of these :woot: for being from MS! (nothing says cool quite like the "cabbage patch")
  6. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    What size thermostat are you running? I run a 190 and my truck likes to hang out around 210 or so when it gets hot, and it's only a year or so old.
  7. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Yup........:o
  8. bettabruce
    Feb 7, 2005
    19
    Jackson, MS
    problem solved
    turns out that my aftermarket SunPro gauge has let me down.
    It reads 120 when the engine is cold, so it must be escalating the
    reading a good 20 to 50 degrees. Thanks for all the ideas.
  9. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Buy the best guage (Autometer) and don't look back.
