Overheating destroying valve guides?
Discussion in 'The Garage' started by mountainexplorer, Jul 21, 2004.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I was just wondering if overheating a motor would have any part in the valve guides/seals going bad?
    This perfectly good running motor that I had just suddenly started going through oil horribly, and the only thing that happened to it was it got really hot once.
  2. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    heat does warp metal...so its possible /forums/images/graemlins/thinking.gif
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    It can also dry and crack seals........
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Yeah, I was going to say that the oil seals are only rubber so its quite possible that that is what happened.
  5. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    It could be the valve stem seals,I kinda doubt the guides would wear out from heat alone--maybe if they were starved for oil--more likely is the piston rings got too hot and lost their spring tension,so they no longer seal well against the cylinder wall--hate to be the bearer of bad news,but it looks like a ring job is in your future,hope I'm wrong though!. /forums/images/graemlins/crazy.gif
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I vote for valve seals ($16 last time I replaced some)...
  7. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    severe enough overheating can make a piston swell and grab the cylinder wall then when it cools down it shrinks smaller than its original size and can now make rings not seal properly. Seals are a pretty good guess that their bad from the heat if it was extreme enough. The only thing can could happen with the valve guides if it got really hot is that a valve could gall in the guide and then you have a sticking valve and will end up bent when a piston hits it because of it being held open when it should be closed.
