Overheating
Discussion in 'The Garage' started by orangeGMC, Jul 7, 2005.
  1. orangeGMC
    orangeGMC 1/2 ton status
    Dec 26, 2004
    184
    Connecticut
    Does any body have any recommendations in order to prevent overheating? When wheeling my climbs really fast, then I shut the truck off and let it cool down. I have no problems on the street or in traffic. Any ideas would be great.
  2. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I took the shroud off and put a 89 Taurus fan in between the engine fan and the rad. and it works perfect, use a relay for the fan or it will drain your batt. those taurus fans draw alot of amps.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    An auxillary fan hooked up to a temp switch so it will come on or stay on when motor is off till it lowers to a set temp. A buddy of mine did that with his fyord.
  4. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
  5. gmcjimmy90
    gmcjimmy90 Registered Member
    Jul 3, 2005
    76
    arkansas
    what are you running stock fan, flex fan, or electric any performance upgrades what engine size
  6. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    A fan shroud can make all the difference in the world....
  7. orangeGMC
    Dec 26, 2004
    184
    Connecticut
    Its a 350 with a flex-a-lite dual puller fan. Hooked up to a derale temp switch. It seems like the fan runs all the time.
  8. gmcjimmy90
    Jul 3, 2005
    76
    arkansas
    switch it back to a stock fan with a new clutch and factory shroud and you should be fine
  9. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    What he said... :xmas:
  10. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    check the pump for adequate water flow..the impeller could be chewed up, a high flow pump may be in order.
    remove the valve from the thermostat...this creates a simple restrictor plate which allows water to flow like the thermostat is stuck open
    make sure the cooling system is purged completely
    replace the bottom hose as it may be collapsing
    write your congressman for suggestions :haha:
  11. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    It might be the fans because I have the same setup and mine heats up when I go up long hills or wheel it hard.
  12. dyeager535
    26,982
    191
    What are the fans rated at CFM-wise? Doesn't matter if electric or clutched, if the fan is too small it will overheat.
  13. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    This is the fan I am running but I changed it to run full rpm when above 180 degrees
    Part #
    292,295/298 puller
    Mounting Surface Required
    17½" x 27½" x 4"
    Fan Diameter
    Dual 13½"
    Fan RPM @13.5VDC
    Variable 1260-2100
    Number of Blades/Fan Blade Angle
    8/26°
    Airflow-Cu. Ft./Min. at 0º Static Pressure
    2760-4600
    Amp Draw
    16-28
    Mounting System
    Universal Bracket
    292 Custom Bracket (Chevy, GMC)
    298 bracket not included
    Adj. Thermostat 160-240 degrees
    Yes
    298 does not include thermostat
    Air Conditioning Relay
    Yes
    298 does not include relay
    Variable Speed Control 60-100%
    Yes
    298 does not include controls
  14. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    what size radiator do you got?
  15. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    How is your radiator? Is it in good shape? Are the tubes clean and not plugged or corroded.
    If your radiator is in good shape then.
    I would get rid of the electric flex a lite
    Flex a lite fans dont pull enough CFMs. You would be better off with stock fan/Clutch and shroud.. Or going with a Tarus/ V8 T bird, lincoln Mk VIII fan, as above post said. But you will need a 130 amp alternator to power it or it will suck your battery dry..
  16. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
  17. dyeager535
    26,982
    191
    If that setup really pulls 4600CFM, you shouldn't be having fan related cooling issues IMO.
    You say long hills, is this towing, unloaded, freeway, logging roads, ?
  18. dendeanda
    dendeanda Registered Member
    Apr 21, 2005
    46
    Corpus Christi, TX
    To me it sounds like a thermostat problem. Take it out then go wheeling and see what happens.
  19. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Everything is new, radiator is a 4 row, new thermostat and its when I am going up steep highways. How much better is the Tarus fan then my setup?
  20. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    with the taurus fan it has not gone over 200 ever , the fan cost me $25 from Langlys auto wrecking.
