Overiding neutral saftey switch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Jun 8, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    How do I do it? Where is the switch located?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I'm not too sure on your '77 but on my '84 it is located on top of the steering column where it goes into the firewall
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    On my '70 when it was an auto it was under the dash on the column.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    prolly a stupid question but what is this switch/what does it do? /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  5. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    It only lets you start the vech. in park or neutral. On manual trans you have to have the clutch pushed in to start. I bypass them on a manual trans trail rig cause I want to be able to start in gear with the clutch out. /forums/images/icons/laugh.gif
  6. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i can only start it in park. mine is a lil F*cked up
    NITRO
  7. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Nitro you're screwed it the truck stalls running down the road as you can't slip it in neutral and crank it up. You'll have to come to a complete stop and put it in park. That's why they work in neutral and park. /forums/images/icons/cool.gif
  8. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Ok, found the switch, and bypassed it. Thanks.
    Nitro, mine also only starts in park (even after bypasing neutal safty switch). It seams to me that mine woun't let the key turn unless the shifter is in park. Is this your problem? If so how do we fix it?
  9. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    you shouldn't be able to turn the key to the lock position exsept in park but you should be able to turn the key to start and have the engine crank in nuetral.
  10. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    The neutral safety switch is easily adjustable. Usually worn out linkage causes for a no start in neutral. I don't recommend bypassing the NSS. My friend had a 77 K-10 beautifully restored. Asked me to start it for him. The truck was lifted and I reached in the window and it almost took my arm off, slamming the truck into the wall. Luckily he was clear of the path.
