OVERKILL FAB PARTS! tabs,perches,gussets, etc...
Discussion in 'Vendor Forum' started by TRAILTOYZ, Feb 23, 2006.
  1. TRAILTOYZ
    TRAILTOYZ 1/2 ton status
    May 21, 2005
    106
    Wasilla, AK
    We've got everything you need for your project at unbeatable prices! If you're looking for the "Toyz 'R US' for the home fabricator, this is it! All of our tabs and gussets are precision laser cut from HR P&O Steel.
    All of our Single Link Tabs, U Bolt Plates, & Diff covers are a seriously strong .375" (3/8) thick.
    We've got:
    [​IMG][​IMG]Beadlock Kits (DIY) - Our 15" locks have 33 - (3/8) countersunk boltholes, 16" have 36 holes, 16.5" & 17" have 39 holes.
    [​IMG]Crossmembers - Different applications - available March 1st, 2006
    [​IMG]Differential Protection - All differential rings are .375 (3/8). Rings are available countersunk. Covers are available in .375 and .25 (1/4). Covers are available with or W/O drain plug. Diff rings are available individually for the home fabricator, or available as an un-welded kit for FF14B, D60/70 & D44's
    [​IMG]Disk Brake Adapters - For FF14B & FJ40's. FF14b spacer kit for brackets
    [​IMG]Gussets - 60,90,120deg, solid or 3-hole
    [​IMG]IH Scout - Spring hangers, perches, and U-Bolt plates
    [​IMG]Leaf Spring Hangers - All Leaf Spring Hangers are .25" (1/4) HR P&O Plate
    [​IMG]Link Brackets & Loose Link Tabs -3 Link and 4 Link Suspension tabs and brackets
    [​IMG]Mounting Plates - 1/4" cage mounting plates. 1.5, 1.75 & 2" OD Tube
    [​IMG]Reinforcement Plates
    [​IMG]Shackles - 4, 5 & 6" Universal shackles with rounded ends, .375 (3/8) thick
    [​IMG]Shock Brackets & Loose Shock Tab - all are .25" (1/4) HR P&O Plate Steel.
    [​IMG]Skid Plates
    [​IMG]Spring Perches - 2, 2.5, 3" wide perches for 2.75-3" axle tubes. These are .25" (1/4) thick HR P&O Steel Plate, CNC Laser cut and CNC 290 ton Brake bent. Sold in pairs
    [​IMG]Toyota FJ40 - Spring hangers, perches, and U-Bolt plates
    [​IMG]Toyota Mini - Spring hangers, perches, and U-Bolt plates
    [​IMG]Trusses - available March 1st, 2006
    [​IMG]U-Bolts & U-Bolt Plates - provide 3 options in leaf spring placement so you can adjust WB (or maybe not have to replace a driveline). They are also set up for secure U bolt retention while being able to fit a variety of axle tube diameters (2.75" t0 3.5"). They are reinforced laterally with a bend of 45 degrees and we have models that will fit from 1.75" (Scout) to the larger 4" (certain GM) leaf springs. They are .375" HR P&O Steel plate and can work with .5625" (9/16) to .625" (5/8) U bolts, we recomend 5/8", why use a lighter piece of steel when you don't have too?
  2. TRAILTOYZ
    May 21, 2005
    106
    Wasilla, AK
  3. TRAILTOYZ
    May 21, 2005
    106
    Wasilla, AK
  4. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    cool Stuff
    I know!
  5. Gravel Maker
    Feb 6, 2006
    2,570
    23
    Sacramento, CA
    Those Link Tabs are killer
    !!!!!3/8" thick, now those could take a beating!!!!!:bow:
