overload-leaf question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Jul 19, 2000.
  1. CK5
    May 19, 1999
    21,622
    701
    CO
    I am going to do a shackle flip soon and will either flip the overload-leaf spring over and cut it shorter or keep it the way it is and cut it shorter, pros and cons to either way?
    Steve Fox
    90 3/4 ton K5
  2. CK5
    May 19, 1999
    21,622
    701
    CO
    Anyone, anyone [​IMG]
    Steve Fox
    90 3/4 ton K5
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: Add-a-leaf question
    Duno, But do you need it or just aticipating you might to level out your rig?
    If you do need it then I would 'test' it buy first installing it the way it was ment to be used then 'feel' the ride and go from there. I wouldn't think your articulation would be effected or change buy cutting it, but again I duno............never dun it!
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  4. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Well, flipping it lets you flex better, I tried cutting mine shorter, did not make much differece.
    Currently I have them flipped and cut the cut off one down to block size and its bolted in with the leaf spring bolts on the bottom.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  5. Grim-Reaper
    7,385
    Atlanta
    I Am running 2 overloads. One is upside down and more or less be came a 3/4 block. The truck gets full stuff and is just shy of bottoming out the shock in it's stock location. When under full compress there is about 3/8 of an inch gap between the 2 overloads and My guess is under torq it will help prevent axle wrap. My springs came out of an 86 and have 4 leafs with the pads. They flex GREAT!
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  6. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    No Grimmy, they flex like Mad!! eheheh
    Actually my 88 springs flex like mad! I just gotta get some longer shocks dammit.
  7. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    hey steve,
    i did the same thing you are asking about, i got the idea from depdog, and it is amazing the amount of compression you get just by flipping the overload leaf. while ramping my truck on some steps i really got a chance to see how well that idea works. stuffs the rear tire into the wheel well, this may be a concern for the fat tire guys. i dont plan on putting anything fatter than what ive got or carrying any heavy loads(other than people) so there is no room for concern for me.
    good luck,
    MTPockets.
  8. CK5
    May 19, 1999
    21,622
    701
    CO
    So the verdict looks like flip and cut.
    Steve Fox
    90 3/4 ton K5
