overload springs+ zero rates,
Discussion in 'The Garage' started by 90BCk5, Jan 10, 2006.
  1. 90BCk5
    90BCk5 1/2 ton status
    Apr 8, 2005
    278
    British Columbia
    so i got my zero rates in the mail today, just went to chuck them on and was wondering if i need to keep my overloads in place, i know i can flip them for a bit more articulation but i was wanna know if i can just get rid of them? or do i have to keep them in place??:confused:
  2. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I am giong to keep my overloads and add the zero rate becasue right now my truck looks like Lincoln towncar that just left TJ. In other words, it sags in the back. I am sure someone else will know, but I suspect that if you take out the overload and add a zero rate, you will get better articulation with the same lift/ride height.
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I have run that combo for 5 years. A little bouncy but it works. And on my overloads you can slip the u bolts off if you want - I never do.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you can take them out no problem. just remember your going to loose the like 3/4" of height that the overload provided.
  5. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    What do you mean you can slip the U bolts off?
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    This not max'd flex either but you can tell it's not too far out of balance
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I can put c clamps on the main spring pack and the overloads and then slip the u-bolts off (of the overloads, they stay bouncing around on the main pack).
    Need pics?
  8. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Yeah, pics please as I am struggling, maybe becasue it is getting towards the end of the day. Your talking about being able to slip the overloads out for wheeling?
    Nice Rig!
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Just disconnect them at each end.... I'll go get some pics.
  10. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Here ya go:
  11. 90BCk5
    Apr 8, 2005
    278
    British Columbia
    thanks for the replys fellas, i think im gonna go get some longer center pins!
    :D
  12. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    I am a tool. I kept writing "overload springs", but was thinking of the fat short spring on the bottom of the pack closest to the axle. That's why when you said unbolt it from the U-Bolt, I couldn't picture what you were saying...now I get it!
  13. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    :crazy::D
    Maybe I'm the tool if this is what the post was intended to discuss....
  14. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    It appears the confusion comes from different people talking about different things.
    Most/all stock rear Blazer's have a short fat leaf on the bottom of the spring pack that does not really make contact on the ends with the rest of the spring pack until the truck is compressed. This is referred to as an overlead leaf.
    The picture 2Dogs posted is also considered an overload leaf pack.........but it's obviously not a stock setup and configured completely different than a stock overload as mentioned previously.
  15. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    So...does that make us both tools?? Ha!
    The overlead spring is the one that gets flipped upside down for better articulation and the overload spring pack is the one that gets taken out all togehter, correct?
  16. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Re reading the original post shows me that I was mistaken - had overload in the head from listening to those things snap and bang over the weekend......:o:D
