oversized tie rods and drag links....
Discussion in 'The Garage' started by thatK30guy, Nov 23, 2003.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    I tried the search and came up with nada.
    Post your links to ANYBODY and EVERYBODY who makes large tie rods and drag links, such as Rockstomper, etc.
    If you can, post up some pics of the ends where there are double tubes as I'm curious to what they look like as far as to whether the tubes are welded together or ???????? /forums/images/graemlins/thinking.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I made my sleeved tie rod and it is welded at the ends. Need one? I only have a right hand tap right now; which I prefer since the right hand tre's are cheaper and easier to come by.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I got mine from sky also. He uses chevy and ford BIG 1" ends instead of the 7/8" ends /forums/images/graemlins/thumb.gif
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    ORD, MOO
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    www.mo-offroad.com
    Or just buy a set of High Steer arms from ORD and don't worry about the tierod! /forums/images/graemlins/thumb.gif
    Down low - they all bend! /forums/images/graemlins/wink.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    www.mo-offroad.com
    I'd rather bend a tie rod than shatter a knuckle. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. Mudzer
    3,639
    Missouri
    Here we go hi-jacking - sorry Wes!
    If your'e worried about it, the ORD arms are drilled for the 5th bolt hole in the Dedenbear Knuckles - so you'll be prepared to shell out the cash.
    I never bend anything because mine doesnt leave the driveway! /forums/images/graemlins/rotfl.gif
    I'll do a Poll - see the new thread...
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Start the thread on pirate, not here.
  10. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I have the ORD draglink (crossover steering) and its beefy. My tierod is from West Texas Offroad and is 1.5" solid steel. Its severe overkill, but I like it. Plus, it was cheaper than anybody else's "strong" tierod.
    Will
  11. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    [momentary highjack in progress]
    Typically, how big in diameter can you go before the tie rod makes contact with the diff cover at full lock?
    How do lift springs effect a high steer tie rod set up? Is there a point where the spring arch causes them (the springs) to get in the way of the tie rod? I'm thinking of doing the high steer tie rod to get it out of harms way but I don't want to find out I can't do it after I've bought the parts.
    [/momentary highjack in progress]
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    On GM knucks, about 1.75" diameter is max for a D60 depending on the cover. Ford is about 1.5" diameter max. You might be able to go 2" on GMs with a stock cover.
    Depending on the arch of the springs, yes, it can be a problem with high steer. But it depends on the manufacturer since arch rate is not consistent on all springs from end to end. Also depends on the arms used. Sometimes you need to space the arm or tie rod to keep from hitting in droop...
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    No problem on the 5th hole as I was planning to send my arm back to Stephen and have him drill the 5th hole out for me. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
