oxy acetylene psi? cutting and welding
Discussion in 'The Tool Shed' started by NJBLZ, Aug 15, 2006.
  1. NJBLZ
    NJBLZ 1/2 ton status
    Jan 4, 2005
    128
    New Jersey
    I read rustyparts post.
    looking for advice, what psi do you set your regulators at for cutting, I was told apporox 30 psi on the oxygen and 8 psi on the acetylene.
    also what psi for welding? I think I was told 4 psi on both.
    thanks
  2. sponsoredbydad
    sponsoredbydad Dune Slaying Sand Junkie Premium Member GMOTM Winner
    Mar 12, 2004
    2,334
    405
    Dana Point "So Cal" "The sue me state"
    I can only tell you what I was taught. cutting oxy-20-30 depending on thickness acetyelene 3 -5
    welding same on the acetyelene and 10 to 20 depending on the tip size and thickness of metal.
    some one on this site will be able to give you a professional answer.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I go more around 25 on oxy and 5-8 on acetylene.
    Flame setting is the most important thing in cutting. Of course psis come into play.
  4. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    I have a quick reference book for oxy-fuel cutting/welding/heating. It gives general guidelines for PSI for different thickness metals and tip sizes. The aforementioned pressures sound about right. If you ask nicely, I can dig through the garage and pull out the book and give you those numbers. It is worth getting this book. Its yellow and from Victor. Shouldn't be more than a few dollars.
  5. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    I usually run the oxygen about 40psi and the acetylene about 5-6psi.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    something wrong with your torch? I never have to run anything near that much oxy unless there is something wrong.
    On another note, how do you guys setup a torch(flame that is)? I used to just guess, now I know what to look for and I cut SO much better now. See if I can come up with an example to show it.
  7. thezentree
    Sep 19, 2003
    7,198
    NC
    That's just the way I was taught to set it up. It's worked for me, so I never thought to do it differently.
    Setup:
    Acetylene on, ignite, open acetylene until there's just barely a hint of smoke, open oxygen until there's a blue flame about 3 inches long, hold down cutting lever and tune oxygen until you get the six tiny flames at the tip of the torch and a jet of oxygen (I forget what it's called) about 4-6" long.
  8. NJBLZ
    Jan 4, 2005
    128
    New Jersey
    tx sub, thats ok i'll look for that book, i think welding shop where i got the setup sels victor stuff.
    as for flame setup, for cutting i'm ok, sombody shoed me what it should look like.
    i need to figure out the welding flame/tip now.
  9. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    if you're welding only use 12-15 oxy psi and cutting at 25-30psi.
    acetlyne always at 5-8 psi welding or cutting.
    The welding flame - open acytl, light, open acytl until there's little smoke. Slowly open oxy until you have a blue flame with a bright blue center cone and no light blue/white cone.
  10. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    NEVER set your ACY regulator above 15PSI
    NEVER, NEVER, NEVER, NEVER, NEVER, NEVER, NEVER, NEVER, NEVER, NEVER
  11. OrangeCrushK10
    Jan 25, 2003
    1,425
    ditto. It'll go boom.
    Also, never oil your regulators.
    It'll go boom.
  12. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Yeah it's good to avoid a "boom". I was taught 40/7, but for thinner automotive jobs, etc., less is OK. You'll get the feel of it. Most of my torch work is with 3/8" and thicker stuff, thinner stuff gets the plasma, unless I'm in the field.
