Oxygen Sensor
Discussion in 'The Garage' started by Chris87K5, Dec 3, 2002.
  1. Chris87K5
    Chris87K5 1/2 ton status
    Sep 21, 2002
    322
    Pennsyltucky
    Ok, I just got new headers and I want to put a 3 wire O2 sensor in when I install the headers. Does anybody have a part number for them. I went to napa but they told me that I they couldn't give me one because all thier computer shows is a single wire one. /forums/images/graemlins/confused.gif
  2. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    Not being a smart arse,but why u lookin for 3 wire?Do you want to preheat your o2? If so just get an o2 for a 96 newer truck big bucks tho compared to a single wire.
  3. Chris87K5
    Sep 21, 2002
    322
    Pennsyltucky
    yeah because I'm getting a code 42 (I think) and I have heard that this will solve the problem
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    well im sorry dude, but these trucks, like mine i have a 350tbi in my truck, i did the o2 sensor replacement on my truck, it was 18.99$ at auto zone, i dont see a neeed for you to get a pricey one, unless you have a newer motor that needs it. but our engines only take a 1 wire one. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  5. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    and code 42, is the electric spark timeing, not the o2 sensor, a code 14 will be the O2 sensor, code 42 means somethin is wrong with your HEI /forums/images/graemlins/eek.gif. good luck /forums/images/graemlins/thumb.gif
  6. Chris87K5
    Sep 21, 2002
    322
    Pennsyltucky
    Its code 44 not 42 i was wrong. 44 is lean exhaust right? I also have a code 24 and 43 if anybody can help with those. /forums/images/graemlins/frown.gif
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    GM Computer Codes
    3 wire O2 sensors ARE a good idea. Heats them up sooner in winter and allows the truck to go into closed loop sooner. /forums/images/graemlins/laugh.gif
  8. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I would try and go through the different years until you find one that has a 3 wire.
    Good luck.
    For some weird reason my Howell TBI unit has a four wire O2 sensor. Howell said "everything" is compatible with an 89 TBI truck. I know it's not, but oh well.
  9. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I was told P/N AFS74 (AC Delco) or 25312179. Stock on a 4.3L. You may want to double check it though I have not done this for myself although I plan to eventually. Also, be sure you soder the wire on the o2 sensor so your getting a correct reading and if your sensor is behind your collector make sure you don't have any leaks.
