p/n switch on 73 blazer location????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Terminaltsi, Jul 27, 2003.
  1. Terminaltsi
    Terminaltsi Registered Member
    Jan 22, 2003
    44
    louisville, KY
    anybody know where the p/n switch is on a 73 with a th350?
    it's been acting weird lately and today just wouldn't crank no matter what position i have the shifter in.
    thanks
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    located on the topside of the steering column........neutral safety switch is at the base, and the p/n selector switch is a few inches upwards of that /forums/images/graemlins/thumb.gif
  3. Terminaltsi
    Jan 22, 2003
    44
    louisville, KY
    hmm.....which is the one that prevents the starter from engaging if the shifter isn't in park or n? which one should i be looking for?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    the one on the upper part of the steering column....its just under the dash piece on the top side of the column....easier to get to if you lower the column from the dash.
  5. Terminaltsi
    Jan 22, 2003
    44
    louisville, KY
    great, thanks.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Np /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. Terminaltsi
    Jan 22, 2003
    44
    louisville, KY
    ok, so i located teh swtiches, and found that the neutral safety sw. is the one with the 2 purple wires. one of them should be getting voltage when i put the ign. sw. in the start position right? if not, then it's a bad ign. sw. right?
  8. Terminaltsi
    Jan 22, 2003
    44
    louisville, KY
    enver mind, i found the problem. aftermarket alarm and bad neutral safety switch combined to make big headache.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Cool, glad to hear you got it fixed /forums/images/graemlins/thumb.gif
