p/s pump and box shot
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Oct 28, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Just replaced the p/s pump and it still makes noise like crazy. Think i wasgiven a bad pump? What else to do/or look for. thanks for the help Mike
  2. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    Have you cycled it a few times? Fill the tank, start the engine and turn the wheel back and forth a number of times, turn off the engine, refill the tank and turn the wheel a few more times. Repeat until the system is filled to the proper level with fluid. The pump will be noisy until you do this. If it is still noisy, make sure the belt is on properly and that the pump itself is not mounted crooked (pullys allinged). If the noise persists then you have a bad pump.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks!
