P/S Pump question...
Discussion in 'The Garage' started by Confedneck79K30, Jan 21, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    is there a stock bolt up upgradeable p/s pump for our trucks? something with more pressure or volume? i need to replace mine and also get new brackets anyone gotten all that stuff and where?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    nice, can you go serp with them? i plan to do that later, but id like to drive this pos for now... mebbe ill get a stock napa reman
  4. goldwing2000
    goldwing2000 Guest
    Factory GM Saginaw PS pumps are some of the strongest ones money can buy. You won't go wrong with a stock replacement unless you have WAY huge tires, and then you should probably be going to ram-assist or full hydraulic.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    PSC and HOWE both make aftermarket saginaw pumps that have increased flow and pressure. They are usually set up for a remote rez and will work with your factory brackets and pulleys.
    Ira
  6. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    i think for now, since its rollin on stock tires, and just to run around and drive ill go reman napa, cheap enough to keep for a spare when i do go hydro assist...
