Paasenger side spring pack off center?!?!?!?... (PIC)
Discussion in 'The Garage' started by fad2blk99, Oct 25, 2004.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    This was my first outting w/ my new front spool and crossover steering. On the way off the trail I imediately noticed my steering wheel was about a 1/4 turn from being center. Before hitting the road, I checked all my TREs and they were in good shape. Upon closer inspction at home I noticed this:
    Anyone else have this problem? I thighten my u-bolts to around 130-150 ft/lbs, the same I've always thighten them to. I'm thinking about welding some angle iron to the u-bolt plate (which needs to be beefed up anyway) to help keep the spring pack centered... Is this a good idea? I may just take the zero rates out (again).
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    broken center pin, usually means that the ubolts are too loose
  3. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    The center pin isn't broken. The spring packs’ center pin is a bolt that attaches the pack to the zero rates; the center pin locating the axle is on the zero rates themselves and relocates the axle 1.5" forward. This unfortunately is what allows the axle to come off center. I haven’t had a problem with this before I got the D60. Not that the D60 is the culprit; I just drive a lot harder now that I got it. I kind of know where the axle got “relocated”…. I was coming over a steep climb (about70*) which peaked sharply and fell back off about 45* downward on the other side. As I crossed the top, the left tire went down in a wash out yanking the wheel hard left. /forums/images/graemlins/eek.gif In order to get out of that little predicament I had to give it some gas and, struggling against the front spool, force the wheel to the right and up and over a 2.5 foot shear bank (might as well been a rock). /forums/images/graemlins/peace.gif The kids riding 4-wheelers nearby really got a kick out of that little show!
    Anyway, I just wanna see if anyone else has this problem and what I can do to keep it from happening w/o loosing the zero rates up front.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Is that a shim in there?
    Your problem IS due to the Dana 60. Didn't you notice that there are two bolts/studs that hold the spring plate down on a D60 front?
    These are now canted at an angle due to that shim. They can't put the proper clamping load on the whole assembly as a result, and the problems are what is illistrated above.
    Get that shim out of there, and your problems will go away. The front axle when you have a Dana 60 is NOT a place for shims.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I don't remember who but someone sells an angle spring plate, I don't remember cause it doesn't matter to me.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    id pull the ubolts off and check anyway, don't wanna take a chance
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why even bother? Why are y'all running shims up there?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  9. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    What am I supposed to do about caster angles (short of cutting and re-welding the yokes)?
    Besides the deflection from the u-bolt plate should offset the mild slope of the shim.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The "deflection" is NOT offsetting anything, which is what I'm trying to tell you.
    That shim isn't doing anything for you but minimizing pinion angle, and causing problems.
  11. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    The caster angle is more important to me than the pinion angle. With poor caster angle the front wheels will lift the truck in a turn as the wheels turn into the ground instead of parallel with the ground… very scary! /forums/images/graemlins/eek.gif
  12. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Mine's the same way, although I don't have any zero rates/ shims, just a spring pack. Both springs angle in a little. It's been that way for 2+ years, I attribute it to having 2-1/2 wide springs in a space meant for 3", combined with the wheelin I do. My .02
  13. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Do all Chevy 1 tons have 3" wide springs or just in your case?
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You're screwing up your caster with those shims, not helping. Caster angle is important to me too. That is why my front axle doesn't have any shims on it.
  15. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    So whats your caster set at?
    A little spring "shift" would be normal in your application as Fred said you have a 3" space and 2.5" springs.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    all 4wd Chevy's come stock with 3" springs, all aftermarkets are 2.5". And it looks to me more like your zero rate twisted rather than shifted.
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and bushings generally make up for that... /forums/images/graemlins/screwy.gif
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    the spring pad is still 3" wide /forums/images/graemlins/rolleyes.gif All Chevy 4x4s that I've ever seen the front springs angle in towards each other. Its not noticeable a stock rig cause the stock springs are flat. Any type of lift spring and you instantly see it, I always have to use a pry bar to get the second center pin in.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's why you don't tighten your spring bolts until you've got the u bolts tight.
  20. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    My caster is off because of the zero rates. Moving the axle forward 1.5" tilts the pinion down as it follows the curviture of the spring. The shim corrects it perfectly to zero degrees caster angle. Believe me, I would not run a shim if I didn't have to.
