Pace Performance Serpentine Kit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Sep 28, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Anyone know anything about this? I think it looks pretty good. I'm pretty sure I'm gonna get it, I may even spring for the one w/ AC, not sure yet. Any idea why it comes with a new water pump? Is it the reverse style? Also, why would it come with an alternator? I thought alts would charge no matter what direction they turned. One more thing, I don't have secondary air injector or idler pulleys, but it comes with both of those pulleys..why? Thanks and hopefully I'm not makin a huge mistake.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I am not familiar with the serpentine kit you speak of, but the water pump on almost all serpentine set-ups is a reverse rotation water pump and if you have a engine driven fan they are different as well. As for the pulleys it comes with, a serpentine set-up must have all the components installed for the belt to be tensioned and driven properly. The alternator will charge in either direction but I am sure that it is a mounting issue they are dealing with, (your current alternator will not bolt in the place provided I am guessing. )
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    got a link for a site to the one you bought? i dont think you are making a mistake. it does save a bit of wear and tear on your parts and is supposed to provied a few more horses.
    i plan on putthing one on my blazer. when i have a motor in it anyway
    grant
  4. BrightBlazer
    BrightBlazer Registered Member
    Dec 17, 2001
    11
    MICHIGAN
    I wonder if it would be possible to swap a newer trucks setup onto an older truck...92-86.
    May be a way to save some cash and to eliminate custom parts that are hard to fix,replace when in the middle of nowhere. I am considering this too.
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yes, that might be possible. but i am sure that means upgrading to hewer items, like alternater. and those cost more. due to pully sizes i am guessing. or shaft lengths for the pullys
    anybody know bout it?
  6. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I believe this is the one he is talking about Belt setup It's not to bad, but your SOL if you have to run a smog pump.
  7. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Yes! That's the one...I'm here in Okie land so I won't need a smog pump. But, I absolutely can't run the alt that comes with that kit. I need something with more kick, and some say that the alt that comes with their package is the only one that will work.
  8. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    I believe the alternators in the police caprices are like 200amp, and I know for a fact the make a high amp rebuild kit for the standard one like they offer, but it stinks that you can't just get the setup you want with the correct stuff
  9. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    I've got a 250 amper right now that I'm sellin. If I could use it in this package, I'd hold on to it. I'd really like a 1-wire alt even though everyone swears against them. I ordered the kit though, I'll post pics after I get it installed.
