"Pack It Up" Great Article!
Discussion in 'The Garage' started by landsmasher, May 16, 2002.
  1. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    \"Pack It Up\" Great Article!
    Boy that was a great and informative article from the Grim Reaper! Now I just need to get another loan to go out and buy all that stuff /forums/images/icons/smile.gif
    I know a guy that packs his spare axle and driveshafts under the hood. He made some mounts for them on the fender wells. Might be a good place for the High Lift also?
  2. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Re: \"Pack It Up\" Great Article!
    how are you gonna fit a 60" hilift under the hood? Will it fit? that would be cool.
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I have mounts made to put a 48" one under the hood, but that project is on hold until I do onboard air. I believe a 60" might fit, but it is going to be a tight squeeze. with grim's techiniques I see no reason for a 60" jack (and if grim doesn't pack one then probably anybody else could get by).
    I just took the time to read that article of grim's a couple days ago, and was blown away with the quality of th write up.
  4. landsmasher
    Mar 13, 2002
    4,423
    I agree. I don't think you need a 60 inch high lift using Grim's techniques... Matter of fact I bet you could improve on that by adding some locking hardware for the axle. Maybe a half inch pin and some quarter inch steel plate. Anything is possible when you know how to weld /forums/images/icons/smile.gif
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah but the 60" is better when you use it as a winch, but Grim already has a winch......
  6. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    about one of the items grim had, where did he find a 20 ft. heavy duty chain, i gotta 8 footer i found in the shed, but need a biggin' (preferably for less than $50) any help thanked (if that even makes sense)
    Brett
  7. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I got a 25' 3/8" chain from Home Depot. I've also seen them at Tractor Supply Company
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I just bought a 20' 5/16" chain from Home Depot. It has chain hooks on the ends (ment to hook the chain back to itself) for $27. It is even a higher ratting of chain then their regular stuff (70).
