Packing the front bearings when you put in new hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bone85K5, Dec 13, 2000.
  1. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    Is this standard when your taking out old auto hubs and putting in new manual hubs?
    Ben
    www.BenjaminBone.coloradoK5.com
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You don't have to re-pack the bearings. But I usually pull mine apart and repack them anytime I have the front end apart for anything. I figure that too much preventative maintenance is way better than not enough. [​IMG] If you do any deep water crossings in your rig, it's a good idea to repack often anyway. You don't want water getting into the bearings and staying there.
    http://ThunderTruck.ColoradoK5.com
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Just make sure you dont get a lot of grease on the hubs as most just call for motor oil for lube!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you have never had the hubs/bearings repacked I would highly recommend doing that. There is quite a bit more work required to get to the bearings as compared to just changing hubs but it's still fairly easy and straightforward.
  5. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    Does this also hold true when repacking bearings on auto hubs? I just did mine yesterday and I greased up my auto hubs pretty good. I hope I don't have to take them apart again.
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am not sure. I know with Warn or aftermarket hubs, they say this in the instructions. I kno I used to "grease" my auto hubs when i had them and they worked fine until the crapped out.
    Mike [​IMG]
  8. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    How long do the bearings last? I usually replace them instead of just repacking them, is this overkill?
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    You will probably get around 60K - 100K miles oput of them if taken care of. But hell, they are not that expensive and if y ou like changing them, I dont see that being too overkill. It would be a preventitive maintenance type of thing! [​IMG]
    Mike [​IMG]
  10. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    When I pack mine I use Blue Boat trailer grease. I smear that stuff everywere. For the hubs I just smear a light coat on all the moving parts and gears. I have the Warn Prem. type and have had no issues with the way I doit.
    I don't see any harm in using a LIGHT amount of grease on the hubs and it's moving parts.
    http://www.burt4x4.coloradok5.com
