Paging Dr. Watson, Paging Dr. Watson
Discussion in 'OffRoad Design' started by willyswanter, Apr 5, 2003.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    /forums/images/graemlins/grin.gif
    Ok sir, my plans are for a 4l80e auto with doubler setup behind it. I curently have a 465 version 205 and I assume I will need the # GU4033 32 spline input conversion for it. Now, I still need to find the 203 which I'm assuming needs to be a 32 spline input to work with the 80e correct? Also, on your site it says use the factory adapter, do I use the adapter that came factory with the tranny or t-case? I'm assuming I use the adapter that is on the tranny and re-drill the 203 to match as your site says may need to be done...
    If I'm all correct in the above let me know so I can start getting my orders together /forums/images/graemlins/grin.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Has anyone done a 4L80E doubler yet, Dr. Watson?
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Shawn is currently in the process of that. He is waiting till after the Moab (EJS) run to install it though I think.
  4. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah, I was chatting with Shawn the other day about his setup. In the end we will have the exact same setup, 496/4l80e/203/205 /forums/images/graemlins/thumb.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i thought you were going CTD? /forums/images/graemlins/confused.gif
  6. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah, thats in the truck. The above application is for the willys /forums/images/graemlins/grin.gif.
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You've got it, you need the 4L80 with the factory 4L80 to 241 adapter, then drill the front face of the 203 to match the bolt pattern. It could involve some mods to the bearing retainer, that part is a bit up in the air.
