Paging North West Fab
Discussion in 'The Garage' started by afroman006, Apr 11, 2006.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    241 doubler progress?
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    x eleventy billion
  3. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    1-250-248-6024
    :wink1:
    Rene
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Here goes the newb question - what other case do you need if they do this?
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I was under the impression it would be a 205 but I could be mistaken. It'd allow you to have 2:1, 3:1, and 6:1 in a lightweight package and without shelling out big bucks for a Lomax or WMS (ATOR) 3:1 set on top of the doubler.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Yall do know there is a kit already for this......
  7. cbbr
    Jul 17, 2004
    14,681
    That's why I was asking - I hve a 241 in my burb and a 205 in the parts rig. Dammit - Paging NWF......
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yep, but it leaves half the case hanging off to the side, and it'd force me to find a good drivers side 241 for the sole purpose of cutting up.
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I think it would be a better option and here are some reasons.
    With the doubler like you are wanting to see (passenger drop 241) you will have shifter clearance problems if you twin stick the 205.
    With the other kit you wont have to do any weldind like you would if you used a passenger drop 241.
    Also a driver drop 241 is a very easy case to find un-like a passenger drop 241 that was only offered in K5's from 89'-91'.
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    From what I understand, NWF was developing a "case" to house existing 241 gears. No muss, no fuss, no front halves of t-cases hanging anywhere...a Klune-ish setup really. Driver's drop 241's are very easy to find, but a big wing hanging out there is one more thing in my when it's time for crossmembers, exhaust, etc.
    We'll see what they come up with, maybe I'll end up with a traditional doubler after all.
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I really dont understand why they kept the half of the case. If they are not even using the chain then why have the rest of the case?
    I might have to look into that some more.
  12. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    The mad rooster 231 kit keeps a big chunk of the case, the DD machine 241 one keeps less of the case but there's still a decent hunk. I just want something that's compact enough to clear whatever shaft/joint I end up with, is (relatively) cheap, and gives me more options than the standard doubler.
  13. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    After looking at it it just looks like it gets cut off next to the planetary section so you wouldnt have much of a "wing" like you described.
    Hmmmm may have to get one
  14. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I just found better pics of the DD machine doubler. I stand corrected.
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    pics? I have just seen the one. Want to send me a link?
  16. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Nevermind, my brain isn't working tonight, I was looking at the wrong stuff. Doesn't look as large as the M.R. 231's though. Hopefully someone will post up a picture.
  17. afroman006
    Aug 21, 2002
    2,876
    So DD machine is already making this kit? Do they have a website?
  18. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I need to see more pics in this thread!
  19. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yes, he is making them. The 32 spline and 31 spline shafts are not ready yet. No, he does not have a website.
  20. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just some info on the DD Machine kit. If you are running a passenger side drop 205 you will need a driver side 241 if you want to shift the 205. You may also have to shift the 205 from the back side if going twin stick. You will need to cut the 241 and have it welded but the block off plates are included in the kit.
