Pain In My @$$!!!
Discussion in 'The Garage' started by jmeti000, Jan 15, 2006.
  1. jmeti000
    jmeti000 Registered Member
    Jul 13, 2005
    33
    texas
    so i just got my oil changed the other day, and all of the sudden my truck starts acting up. heres the deal. starts out cold with 60 oil pressure and sounds great, then slowly drops to about 10 as i drive it. when i accelerate the pressure will go up, but then gradually fall..again. and there is a tapping noise i noticed today when i got off the freeway. was on my way home and it sounded horrible at the stoplight. after about 3 miles of 35-45 mph the tapping went away and didnt return, however the oil pressure had not moved from 10. i pulled over and popped the hood at one point and it sounds like its coming from the passenger side rocker covers. mind you the pressure has always done this, but the recent tapping sound is whats killing me. any ideas or experiences with this??
    thanks
    jac
  2. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    Sounds like either a lifter that isn't staying "pumped up" or you need to adjust the valves, what kind of tapping is it sound wise???
  3. jmeti000
    Jul 13, 2005
    33
    texas
    very rythmical....tapping. but does get faster when i accelerate. it sounds like one of the rockers is hitting the cover, but i would think if thats the case it would do it all the time, not just after freeway driving. it wont do it when its cold. i have only heard it after getting off of the freeway thus far, and like i said, it went away after about 3 miles and i couldnt get it to do it again to listen when i got home tonight. the engine has about 54k on it so i wouldnt think its going bad yet..unless they did a crappy job. am taking it back to put 20/50 in it tomarrow to see if that helps. i bought a oil pump today but im still not completely convinced that could be even part of the problem....could it??
    jac
  4. bobalob
    bobalob 1/2 ton status
    Jul 20, 2005
    157
    Everson, Washington
    I had very similar problem (oil psi/tapping) and when valve cover was removed you could see that a few of the lifters had tons of play and were barely coming up. In the end it turned out the pressure relief valve in the pump was sticking and the lack of oil psi resulted in wiped out cam lobes+lifters.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Have you checked the oil level since you had the oil changed? Have seen some engines that they dont screw the drain plug back in all the way and it falls out or leaks. A low oil level will cause tapping! Or an improperly filled oil level...
  6. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    10psi is not good for oil pressure. your top end will suffer first from lack of pressure, especially hyraulic lifters. Doesnt do it as much cold because the oil is thicker and more viscous.
    hate to say it but get ready for disaster soon.
  7. jmeti000
    Jul 13, 2005
    33
    texas
    alright, i just got back from the shop...i had my oil pressure sensor changed and put 20/50 in it. my oil pressure gauge works great now, says i run at about 30-45, and idol at about 15. and no more ticking. im guessin it didnt like the 10/30 very much after running for a bit...anyways, hope this helps someone a little. thanks all for your help, and till next time
    jac
