Pain in the @#$#%$^&#%!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brady, Feb 24, 2001.
  1. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Don't you love the seamingly easy projects that turn out to be a pain.I just put new rear shackle bushing on my blazer.ORD's greaseable ones.One side was a piece of cake.Jack the rig up un bolt the old pair( I had an extra set ready to go with the new bushings),pull it off,bolt new pair on.No problem,Then go to the other side, remove nuts, pull bolt out of spring,try to pull bolt from shackle, no way.Get hammer, No way!! get bigger hammer, No way!!Get grinder, grind head off bolt, try to hit other direction,No way!! Get sawzall start cutting bolt between shackle and bracket.Cut for a while,Change blade,One side is cut. Start cutting other side of shackle,cut for while,change blade.Cut through.Goto put new one on, put bolt in spring, put bolt in bracket,No way! Pull apart ,put bracket bolt in first,Can't get shackle to line up right,decide I was closer with the bolt in the spring first.Try again.no good.Get grinder out and grind bolt to a point,Finally it goes in.Tighten bolts Done!!!All of this in intermitent snow showers with no garage.Brady
    '73Beautiful Disaster <A target="_blank" HREF=http://beautifuldisaster.coloradok5.com>http://beautifuldisaster.coloradok5.com</A>
  2. CK5
    May 19, 1999
    21,627
    704
    CO
    Re: Pain in the @#$#%$^?%!
    That sounds like exactly what happened to me, it was the passenger side that was a bitch!!
    Steve
    Mall-Running poseur 4x4 with curb-feelers
