Painless Headlight Relay Conversion Harness
Discussion in 'The Garage' started by opfor2, Nov 22, 2006.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Well, I'm just plain lazy and I would like to take the easy way out in doing the headlight relay conversion on my 90 Blazer. But I'm totally confused as to which painless wire harness to buy. My 90 Blazer has the 4 small pencil point halogen headlights so I need some help in getting the correct kit. I would like to avoid cutting and splicing any of the wiring.
    Thanks a million,
    Dan..
    Harness # 30815
    http://www.painlesswiring.com/InfoSearch/partnumber_list.php?SearchField=30815&Submit=Submit
    Harness # 30816
    http://www.painlesswiring.com/InfoSearch/partnumber_list.php?SearchField=30816&Submit=Submit
    Harness # 30817
    http://www.painlesswiring.com/InfoSearch/partnumber_list.php?SearchField=30817&Submit=Submit
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    #30815 Looks to be the one......the other two are for the newer style (non sealed beam) style lights with replaceable bulbs.
  3. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Well first off thanks for the response, however, according to the painless web page states the following: NOTE: Vehicles using dual filament, halogen sealed beam or H4 conversion type headlights please use kit #30815
    So does this mean trucks using two headlight system or four light system?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Chances are that they don't make one for your rig. :( Those lights were only used in a few applications and take a unique connector. I'd recommend that you talk to someone at Painless before you place an order.
  5. SLOK5
    SLOK5 1/2 ton status
    Apr 25, 2005
    216
    SAN LUIS OBISPO CA
    Are you tring to make all 4 lights come on using High Beams? If so all you need is a relay and about 2' of wire.....I did mine in about 15 min and thats 10 minutes looking for the parts in my garage.....:wink1:. If you just want more power to the lights the battery is right there and you can use the exsisting head lamp wire to activate the relays....cost you about $10.00-20.00 at the most.
  6. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Dual filament is hi & lo beams in one light, so they are talking about 2 headlight systems.
    I'm thinking #30815 but with HarryH3's response I'd suggest you contact Painless to be sure.
  7. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    go check out the lmc website they got light harness there but they aint painless brand
  8. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Thanks all I kinda gathered that the connectors would b the problem. I'll check into the cheap LMC harness.
    Dan..
