painless wireing
Discussion in 'The Garage' started by dheavychevy38, Jan 28, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    has anyone ever used a painless wireing kit for a old chevy say 86 if so how was it???? /forums/images/graemlins/truck.gif
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Well, no, not for that year, but I did buy a Painless set-up for the cab-truck (PN 60201 TBI Harness), and I must say I am very impressed with it thus far. Everything is labeled, color coded and ready to go. Before you buy, shop around...I got this one for $306 from the local Autozone.
    Good luck rob
  3. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    I Got the TBI wiring kit for my 85', when i swapped in an 88' TBI. It has been in for about 10 months now and no problems. Everything in the kit was labeled and very striaght forward. I have no regrets thus far.
  4. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    I used one about a month ago. It has all of the core stuff you need. I used the 18 circuit for the 86 truck painless part # 10205. Like the others said it is all color coded and the wires are numbered. I found that the instructions were lacking in inforamtion. It has leaves out some of the things taht were on the 86 model also, or at least what was on mine. For instance, there are no porvision the the electronic spark control system to the distributor, or the wiring that goes into the carb. THese are problems that I had, but you may not have this stuff on you truck. I post a pretty exstensive critique on the whole porject. YOu should find it if you search for painless wiring. IF you do the install and have anymore specific question email me at Dunc03@aol.com. I delete at random because I get so much junk mail so bold the subject and put something like Painless Wiring Question. That way I won't accidentally delte it. When you search the forum make sure that the section down at the bottom is on "all post", then just search for painless wiring and there are numerous post about my review of the project. Just find the ones by Dunc03 and read those, and it should give you a pretty good idea of how the project went. Hope this helps in your decision making.
