PAINLESS WIRING? IS IT REALLY "PAINLESS?"
Discussion in 'The Garage' started by bluesman420, Apr 24, 2005.
  1. bluesman420
    bluesman420 Newbie
    Apr 23, 2005
    bethany, ok
    HAS ANYONE COMPLETELY REWIRED THERE K5 USING PAINLESS WIRING HARNESS KIT? HAVE AN 84 K5 THAT NEEDS IT REALY BAD....ANY SUGGESTIONS OR ADVICE WOULD HELP....THANX IN ADVANCE. :k5:
  2. grape
    grape Registered Member
    Mar 10, 2005
    27
    texas
    would like to hear also, my truck is a bare shell and the stock wiring was in such bad shape i took pictures, but i really don't want to put it back in my totally redone truck. To add, i get to change the under hood harness for my diesel junk.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    we used a setup from them at work. was vary easy and painless in my opinon. and great customer help also. had 1 problem but wasnt there fail at all . and still going fine to this day. he drives it all over town.
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Used one of the 18 circuit kits on my 56. Great quality and the wires are labeled every couple of feet.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    From what I understand, the only thing "painful" about Painless Wiring's kits is the cost.
    But from what I've read, if you gotta re-do ALL the wiring in the vehicle, they're worth every penny. If I was re-wiring a whole truck, I'd probably save up and go Painless.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    A flat fender came to me for sorting out. Owner had attempted to install one their Universal loom kits. When I pulled the instructions out of the box he had used a sharpie and crossed out the "less" and written "full" above it.
    Took me a while to sort it out and I had to get them to send me a copy of what the junction block's internal wiring was. Wire was decent quality stuff. Can't say I was overly impressed by the kit though. Then again, I'd just come from installing a Ron Francis Wire-works.com loom kit. Those will spoil you.
  7. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I couldn't afford one of those hi-dollar kits, I just kept my eyes open at the local picknpull, found a gm truck that hadn't been hatcheted and pulled the harness myself (without cutting anything) costed me 80.00 plus 2 hours of my time. took about 4 hours to install it, it works great :D
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Their FI harness was a snap! Id assume their kits to rewire a vehicle would eb jsut as easy. I plan to put one in my K5 sooner or later.
  9. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    a buddy and I wired this little buggy up with a Painless TBI harness and their 18 circuit racing harnes and it was pretty easy. We had to make modifications of course because we used switches and a push button start instead of a key. the harnesses are well made and labled and when we were done...it fired up on the third roll over.
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thays a pretty bad ass "little" buggy!!!!! :D
  11. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    Yeah, built big block, TBI, 2 1/2 ton Rockwells, full Hydro steering, turbo 400, 203/205 twin stick, yada yada
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I did my 73 with a painless, i was pretty simple, just alot of work, i would absoultly buy from them again,
    Infact i will be rewiring the mini soon and im going to be using one of thier Hot Rod harnesses :waytogo:
