Paint gurus ... advice needed
Discussion in 'The Garage' started by **DONOTDELETE**, Aug 27, 2002.
    I'm looking at getting a spray gun and I would like to know what the difference is between a siphon gun and a gravity feed gun. Which one do the pros use, or is it just personal preference?
    Also, since I'll be painting the cab, how do you go about spraying on a horizontal surface and get an even coating?
  1. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Some prefer a gravity feed gun, but I like the siphon style since I feel they have better balance. I've also found that they work better at funny angles than the gravity guns. As for painting on horizontal surfaces, it's basically the same as on a vertical surface, just make sure there's enough paint in the gun so the pickup doesn't come out of the paint and make the gun sputter. </font color>
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I used a gravity feed gun when I painted my truck. Worked great. The hardest part was reaching the middle of the hood when shooting the clear coat /forums/images/icons/tongue.gif
  3. Okay ... it's a tie - one to one! /forums/images/icons/smile.gif Anyone else? /forums/images/icons/confused.gif
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Not a guru. I painted my truck with a HVLP gravity gun, and a Standard Siphon gun. The HVLP gun wins BY FAR!!!
    I like the ability to see how much material is left. I also used a 1/2 a gallon of mixed material (DAU) for my bed on my '71 truck. While I used 1/2 gallon of mixed (DAU) material on my ENTIRE '73 Blazer (inside and out) with my HVLP gun. Now if I could find/afford a siphon HVLP gun. That might be the way to go.
    Good luck.
  5. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    It's basically just what you would prefer. I have always liked gravity feed becouse there is no cup underneath to accidentaly bump into paint. I haven't seen many painters use siphon feed exept for primers.
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I think SHARPE makes the best gun for the $$...I have a Colbalt gravity feed, I think it was about $135!! Check it out here: http://www.sharpe1.com/cobalt.htm Gravity feed guns use less material and you can use every drop of paint......a siphon feed is OLD school, I got a couple collecting dust right now..... /forums/images/icons/crazy.gif All guns have an air-cap that can be adjusted for side to side or up &amp; down spraying!!
  7. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I use a sharpe (siphon) and get good results. I think one of the key players with it is it does not have a little piece of hose for a pot breather, it has a network of plumbing inside of the pot so you can just about hold it upside down with no drips from the breather tube.
    John
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I did body work and paint for quite a few years. IMHO go with a gravity feed. Clean up is easier and a good one will last for a long time.
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I prefer the gravity fed as well. Shooting the paint is a snap, the clearcoat on the other hand is where most errors happen.
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Sounds like the gravity feed is preferred. Perhaps I prefer the siphon style only because that's what I learned with and have spent a lot more time using. </font color>
  11. JK5, where did you find the Cobalt at for $135? The auto paint shop I went to wants $175 for it.
  12. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I got mine at a Sherwin Williams Automotive paint Store!!! I paid $175 for my Iwata LPH-94, a great clear coat gun.....did you look on-line?
  13. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
  14. Thanks, that's just what I was looking for. /forums/images/icons/smile.gif
