Paint on drive shafts
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by skyblazer, Aug 3, 2001.
  1. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Just finishing up installing the driveline in my 72 K5. My neighbor claims that painting the driveshafts will throw off the balance. Any thoughts?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    hmmm....... I would have to say an even coat of paint will not do a damn thing to the balancing. The balance weights are way heavier than a coat of paint. I don't know for sure this is just my thoughts..........
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. skyblazer
    Oct 1, 2000
    209
    Houston, TX
    Thats what I thought, thanks Burt. Hey did you ever build that 383. I'm going to start on mine today. I've got $2000 in parts sitting in my living room and my wife comes back tomorrow..doh.
  4. Burt4x4
    6,854
    hahahaha, no but I am still going to doit! I have a 350 block and I am working on getting some heads next. The good thing is my current 350 is still running fine so I can take my time with the 383 build up.
    talk to ya later
  5. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I painted my with engine paint gm blue
    IF its not broke , break it and upgrade it.
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Your neighbor's nuts. If the paint is fairly even, you will be hard-pressed to throw the balance off by an amount that is many orders of magnitude smaller than what the driveshaft machines are capable of measuring. Think of it this way: A driveshaft is about 2.5" in diameter and a clutch cover is about 13" in diameter. If the coat of paint is just slightly uneven on either of them, the clutch cover will show it more. A lot of clutch covers have paint on them. FWIW, I have balanced clutch assemblies and repainted them with no ill effects (on engines that routinely saw over 9K RPM).
