paint removal
Discussion in 'The Lounge' started by shaun, Jul 5, 2005.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Does anyone know the best way to get paint off of rocks? We are doing some graffiti clean up at a climbing spot here in NV. We have no running water up there but we do have a gen. I am thinking about a flapper disc on a grinder. We have tried goof off, paint thinner, laquer thinner , just about every chemical and we cant get it all off. Does any body have any suggestions before we turn to angle grinders and flappy discs.
  2. shaun
    Apr 22, 2003
    745
    We r talking spray paint by the way.
  3. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    I would think that sandblasting would be easiest and fastest.
  4. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    :doah: that goof off crap is suppose to work...hmm....wire brush???
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    easy off or aircraft stripper and a welding brush... gloves and tarp off...
    blasting would be best obviously....
    props to you for the effort... :D
  6. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I was thinkin wire brush and cordless drills. Maybe corded with those dc to ac things.
    Yes I own two of them just can't remember what they're called.
    Transducers? Inducers? Converters?
    Anyway, one of those and corded or cordless drill motors and wire brushes.
  7. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I would try a heat gun, they are killer for taking paint off everything else. Just hold it still till the paint bubbles, and then wipe it with a wire brush.
  8. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Aircraft stripper will get anything off, including skin! (don't ask)
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Brake cleaner melts away all the spray paint that I use.
  10. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    A friend of mine used to sell "graffiti remover" at his store. It comes in a spray can and he said it would take spray paint off just about any surface... rocks, signs, fence, etc.
    I googled "graffiti remover" and there's a ton of products out there, but I can't remember the name of the particular brand that he used to use. Good luck :waytogo:
  11. shaun
    Apr 22, 2003
    745
    Goof off is the "Graffiti Remover" at least that is what it says on the can. You have to actually climb up a rock to get to this graffiti so a sand blaster wont help. It is about a 150 ft climb . The words are big hence the reason we are bothering with it. I guess we can try air plane stripper maybe it will work better than goof off and some more wire brushes.
  12. shewheeler
    May 4, 2001
    3,384
    Hollister, CA
    The graffiti remove that I'm referring to isn't "goof off". It's commerical grade stuff that is used by the City and anti-gang task force to remove graffiti. He owned a traffic control and safety supply place. You couldn't purchase this stuff at Wally World or Target.
  13. shaun
    Apr 22, 2003
    745
    You cant purchase goof off at wally world either. THis is an industrial grade chemical that they sell at a local tractor supply store. It probably isnt the same but it does work pretty good. Yo can wipe paint off of anything but this rock isnt smooth so it doesnt work as well.
  14. shewheeler
    May 4, 2001
    3,384
    Hollister, CA
    Okey dokey... wasn't tryin to be a smarty pants, I was just tryin to help.
    Good luck with your painted rock
  15. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    good samaritan...
    I applaud you for trying to right someone else's wrong--(the grafitti)...but whats to prevent the vandals from returning the day after your done cleaning the rock?....sounds like a thankless job to me..and one that will be in vain.. :doah:
    I'd say sandblasting too,but you say its too far up..maybe a propane torch with a flame spreader would soften it enough to scrape it off..no matter what method,its going to be a balbusting job...any clue if its enamel or laquer??--even paint stripper will be hard to apply and remove under those conditions..I doubt mother nature will remove it quickly either..
    In my hometown of Fitchburg MA,there are some cliffs visible from the town common (Rollstone Hill)...some high school pranksters climbed up there and painted "FHS" (Fitchburg High School)on the face of the cliffs--I havent driven by there lately in the daytime,but I bet its still visible after 30+ years..have to look next time I go by there!...they talked about catching the culprits and "sentencing" them to clean it all off,but they never could prove who did it.... :crazy:
