paint removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ZfromNJ, Feb 20, 2002.
  1. ZfromNJ
    ZfromNJ Registered Member
    Jan 26, 2001
    99
    New Jersey
    I was wondering if anyone knew how I can take the home paint job off my hard top. I did some research on it and people were telling me that some strippers might effect the composition of the fiberglass. What do you guys think?
    {crazy}
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Chemicly stripping it will prolly make it fuzzy, I would just sand it down by hand or with a DA sander.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
    ZfromNJ, yes, “paint-strippers” may damage the fiberglass. Remember, fiberglass is a composite blended with sheets of fiber. You want to sand it as PowerMad mentioned. Also, you may not want to strip it completely because the old paint &amp; primer will act as a good base. Of course this depends on the condition of the existing finish. Just remember to use a good primer before painting. Rent a DA (or buy one) and good luck.
  4. ZfromNJ
    Jan 26, 2001
    99
    New Jersey
    thanks fellas I am planning on doing it this weekend and I will let you guys know how it comes out.
    {crazy}
  5. testosterone
    testosterone Registered Member
    Aug 7, 2001
    85
    Las Vegas
    yes, I sanded my top down...actually just scuffed it with a scotch brite pad...and had it painted along with the body...came out very nice..also added (before the paint) a few cans of texture...
    good luck
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    First of all, I wouldn`t use stripper, unless the paint is cracked and flaking and you`ve removed the glass and weaterstrip!! I`ve used zip stripper on fiberglass before, not AIRCRAFT Stripper, most tops were gelcoated at the factory so it hard to harm the f-glass. I`d try a small section first to make sure there are no problems!!
