paint sprayer
Discussion in 'The Garage' started by dammit32, Jul 27, 2003.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I need a paint sprayer to spray some body panels and some other small additions and i have a 6 hp compressor but I am clueless to which ones are good. any help is apreciated
    Clueless in Maine
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I got a Sharpe Cobalt HPLV gravity feed gun. You should be able to find it on the web for around $150. If you're going to be spraying primer too then get a cheap spray gun for that since the metal etcher in the primer will destroy your expensive gun. You'll also need a water filter if you don't already have one.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    HPLV
    high pressure low volume
    the goverment is trying to get rid of them. but they are great guns. today lots of folks are trying to go to the HVLP
    high volume low pressuer.
    wastes less paint, but if you are trying to blend/fade then you can run into problems.
    with a HVLP you use less coats and they are thicker.
    personaly if you are just going to be painting a few things once in a while i would look at a less expensive gun. once you decide you want to do it more and get addicted then some of the higher end sealess guns in ethier format are good. the sealess design makes cleanup a snap.
    GRant
  4. rampage
    Mar 20, 2001
    2,261
    73
    Yep, that's what I meant, a Sharpe Cobalt HVLP gun. *remind self to proofread next time* /forums/images/graemlins/thumb.gif I don't think you can find HPLV guns anymore.
