Paint the TOP?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 18, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    The removable op on my truck needs some paint bad as of now it is brow on top but it is suppsed to be white I can start to see the fiberglass coming through the top should I have a pro paint it orI have a friend with a spray gun and compressor or should I use the spray cans? Also what do I need to sand it with or do you?
    Thanks Brian
    1985 GMC JIMMY
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Hardtop is cake to refinish - Use your buddy's spray gun for the best results. First sand it with 220 grit paper, and lay down your primer/sealer (use an acrylic enamel or urethane primer - lacquer based will attack the fiberglass). You'll want to lay down several coats of primer if the 'glass is showing. Give the primer a day or two to dry, then wet sand it with 400 - 600 grit paper. Now is the time to clean the hell out of it, including every nook and cranny. Once it's clean, you're ready for your topcoat. I've always liked either Martin Senour, or Acme acrylic enamels for this sort of job, easy and economical. Or if you are really just looking for quick and easy, alot of folks have done their topper with oil based enamel and a roller.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    By chance do you have any pics of a finished one?
    1985 GMC JIMMY
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Sorry - sure don't. Mine's due for a repaint too. There's quite a few guys on here that have redone theirs - look in the member's galleries for pics.
    Dos mas Tecates!!!
  5. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    "Oil based and a roller".....I like it, like it a lot....Look for my white top to be appearing tan in the near future.....[​IMG]
    Shane
    Never argue with idiots; They will drag you down to their level and beat you up with experience [​IMG]
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>I'm thinking of repainting mine next year too !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
  7. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    just remeber when you are sanding it to wear a breath mask. I dont think you want to be breathing in fiberglass dust.
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  8. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yeah get the mask... I just did mine and cripes when I took off the mask I was shocked to see the amount of crap on it I could have been breathing in.... [​IMG]
    How can I miss you if you won't go away? [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
    &lt;&gt;&lt; 1 Timothy 4:12 &gt;&lt;&gt;
  9. blackdog
    blackdog Registered Member
    Aug 8, 2001
    98
    New Jersey
    <font color=black>hey, I'm going to be doing mine soon as well. Does the texture on the tops generally sand off easily so that you can have a smooth top? Or would it take more sanding than you would ever want to do yourself? I can't tell whether the texture is an element of the present paint, or part of the fiberglass itself. Is the 220 paper just to do a general purpose prep, or will it remove the texture.
    Ideally, what I'd like is to have the top smooth with the seams filled in.
    <font color=black> "Where did all these people come from, and how soon can they leave..."
    -OLD 97's</font color=black>
    <a target="_blank" href=http://www.k5.batcave.net>www.k5.batcave.net</a>
  10. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I had my top smoothed and painted to match my truck for $200.....I'll try to get picture...sorta hard to tell because my truck is Dark Blue.....
    Stuck?...Hell no..I still got some gas left..
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The texture is in the paint - 220 will take it off pretty easy.
    Dos mas Tecates!!!
  12. blackdog
    Aug 8, 2001
    98
    New Jersey
    <font color=black>Very cool. if it wasn't raining, I might have talked myself into starting it this afternoon...
  13. i rattle canned mine with hammerrite paint. i have lots of trees here so i get tons of scatches. this way its easy to touch up and best of all- cheep!!!
    <font color=blue>Striving for K5 world dominance</font color=blue>
  14. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    ...The rain will keep the fiberglass dust to a minimum......I say "GO FOR IT"!!!! [​IMG]
    -Greg72
