Painting Aluminum?
Discussion in 'The Body Shop' started by trollporter, Jun 10, 2004.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Is there any special prep work involved? /forums/images/graemlins/1zhelp.gif
  2. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    what kind of aluminum product is it, rims?
  3. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    my dad runs the USPS body shop in Chicago, i had asked him before about painting an aluminum john boat, he had said there is a special primer to use for the paint to stick.
  4. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    It is a peice of 1/4" aluminum diamond tread that I'm using to make a set of 1/2 doors for the /forums/images/graemlins/k5.gif.
  5. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
    like he said above, there's a primer to put on it to help make it stick.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    alodine.
    i dont know if a non comercial place can get it. its a corrosion preventative deal as well. you have to clean to a water break free surface. then you apply the alodine as per directions that im not going to go into as with different brands they varry a bit. then a light coat of non zink chromate primer, you can get it in spray cans or two part, then you LIGHTLY sand the primer and hit it again, then you paint it. now, this is for aircraft methods, so maybe automotive methods are different.
    Grant
  7. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I think Eastwood has a primer for Aluminum. I have seen it done before.
    -Chris
  8. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    zinc chromate is the primer. just a couple light coats is all ya need....
